no, official weights coming, will post when available. will be more i'm afraid.
i think the stock GTR wheels are 25.6 lbs F and 26.9 lbs R
a dedicated track set up is coming though so won't effect performance where it counts.
Looks great, Mark. Nice choice in wheels.
I think a little height adjustment will really set it off.
If only my driveway would let me! have to guide the thing in and out every day as is. only solution is to buy a new house and garage.
  • 5 weeks later...
  • 1 month later...
Just thought i'd post up here as well since its relevant,
for those looking for aftermarket wheels for their GTR. the Enkei GTC01 is now available special fitment made for the new GTR in 20".
more info and pictures in my other post in the trader section : http://www.skylinesaustralia.com/forums/R3...-G-t280086.html
We also have the OEM Bridgestone in stock, and have the dunlop on order for unbeatable prices as other GTR owners have found out when shopping around(and cheaper than importing from tirerack etc...)
PM for more info or details.
Ali
Ali
Can you PM me with the details on price of the Bridgestones and the Dunlops as we are about to put an order together. I can't PM you as I don't have enough posts yet being green to all this forum stuff
Thanks
Ali
Sounds great, any indication on the Dunlop prices? and out of interest has anyone tried the dunlops at the track, relative to the bridgestones? really would like some hard data on how much quicker they are from those who have tried them
I have the Dunlops on order with Taleb Tyres, they are going on in the next couple of weeks, a track day booked for late August, so I will let you know.
I will back up their pricing, I shopped everywhere and these guys did the best price for me....I would 100% recommend them.
Cheers,
Gibbo.
Seen a few after market rims for R35, some nice, some not so nice, all I will say on the topic is that the Original factory rims look best and IMO are the best looking stock std factory rim on ANY production car at the moment. I can understand people want something different, but gee I reckon Nissan REALLY nailed the formula with the look of standard alloy.
We run the Dunlops, they are quicker everywhere ;)
yeah, going with the stock wheels and the dunlops for track use for now. Especially since people are starting to provide reasonable pricing for them.
BTW Martin, the Midpipe arrived today, its in the boot for now...
Edited by handbrake
yep, I have tried both the dunlops and the bridgestones. not sure how "hard" my data is, but the dunlops are definitely better on track. :P better than some semi's i tried too on 19s.
I reckon getting a set of dunlops on your stock rims for track and keeping your HREs with the bridgestones for street is a good idea handbrake. :D
but the bridgestones are definitely better on track. :P better than some semi's i tried too on 19s.
Dunlops I hope, about to pull the trigger on them anyway!
Edited by handbrake
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
