Awesome racing vids as always from Kingscorp :cool:
Question: What happened to all the later model (series 6 or later) RX-7s that from memory were seemingly dominating the category in some races from last year that you posted?
good work Noddy (or Sara probably!), a bit of time with video editing and sound really shows up stuff like my video.
was that your first time around OP? You are going pretty damn well, excellent mid corner speed so you are making the most of what the car has. Now all you need is 400kw like all the talkers in the forced induction section.
The slicks rock for the mid-corner grip Duncan. Takes a little while to adjust to as the feel quite different to semi's. 400kw would be nice but what about driveability and control. I'm slowly working on a motor that hopefully have both. Should be a nice step up......1 day.
Awesome racing vids as always from Kingscorp :rant:
He won the 2008 Championship in the RX7 and has now moved to a big National class. IPRA
My 180 wasn't ready for Winton on the weekend, so I took my stock STi instead. Semi slicks would have been nice, but it ran really well, just needs a bigger rear swaybar I think. Best was a 1:43.1. I'm sure it would have done a 42 with another session but in the interest of my tyres and wallet I called it a day!
Phillip Island with the targa cars. I stuffed the clutch on the start and did the rest of the race without it.
speaking of over temp...I had to retire from all 3 races, water temp over120o
not cursed, that was my fault.....I know when I launch it too high the clutch slips (done it once before). It was running way hot in 20 min races but it will be fine for the super sprints this weekend even though the weather looks hotter, it was fine for the first couple of laps.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
