thanks heaps chris :] yea pretty happy with the day, the time of 58.05 on natsoft is incorrect as my GPS and video both agree with each other. old fella mustv been too quick pushing the button.
also on lap 3 of the 2nd vid split times indicate i was on course for a 58.18 for until i made the mistake, bugger.
Edited by scooby36
Ive always known Lakeside to be a high a speed circuit but thats the first time ive seen the speedo on a vid too, thanks Callum!
and just saw natsoft too - fastest lap of the meet - top work!
Do you not watch my vids Chris? lol :P
..... above on a very worn set of O3G's. Note the coner speed difference especially on the turn onto the straight Cal!
Edited by Marlin
thanks heaps ben, good to see ya yesterday.
watching mine afterwards i am relying too much on safe understeer and its probably costing me time and killing my front tyres. i will adjust the balance for next time.
looks like the aero helps my mid corner speed a fair bit compared to yours.. weights being about the same 1190 no driver? and i have a lot of tyre too, 235/255
It's a fantastic little track Chris, you need to find the time to get up here mate :)
I'm 1240 no driver from memory when I last corner weighted it.
Mine's screaming for a front splitter, it improved with undertray, splitter hopefully a step better. If I can get the front to tie up a bit better I can wind some wing back in on the rear.
Love it ^^ , looks like it wants to lift the tyres off the ground under hard brakes!
and man toffy the amount of lock you need to wind in to turn that thing, im getting tired just watching !
explain the gearbox.. simple 3 speed yea? looks fuggin fun but hard work!
yeah three speed (think of starting in 2nd and that's about it) , i need to adjust it a lil better so i don't have to do a z to go from first to second :blush:
Toffy from 8:00 onward is madness. Cars all over the place.
yeah that whole race was like that, it got worse in memory , the top 8 cars ar within 5 hundredths of a second of each other in memory (although it doesn't seem it in the vid ). it all comes down to qualify/start line take off pretty much
Edited by toffy
They are nice vids. I cant help but think that the footage you are getting is better then what I am getting out of my Radcam...will have to try some of the settings on my thing.
Also, do you know where the timing beacon was located on the weekend, by my vids I was doing 1:07-1:08s on the short track, but I suspect I was backing off after the finish line and I suspect the beacon was on the back straight now that they have me 6 seconds slower?
The timing was screwed up on the short track. Winton timing gave me a 1.10.x, racechrono gave me a 1.08.x and video gave me a 1.08.x
The long track timing was working correctly though.
As you say the beacon may have been somewhere else for the short track....?
I use the Go Pro HD's in centre metered mode all the time. This means that it takes light readings from the centre of the video and not from inside the car.
I'm cutting the vision of mine at the moment, but this is in my brothers car (white 33 gtst).
Got a couple pieces of lightning in the video, crazy stuff.
Watch out Stagea it's coming for you!
Yeh, its doing everything pretty well. I just need more seat time and need to get the general balance back to how it used to be which is to make it a bit pointier so i can drive it a little more on the throttle mid corner and get some better drive out of corners.
What is done to the front end of your car? It seems to need more steering angle then mine...but that could be tyres?
Good vids guys :thumbsup:
Great to see the silver beast in action Troy. As for Richos steering angles...maybe its a 33 thing as mine seems to require a fair bit (will have to check my winton footage to compare) so much so that it feels uncomfortable to keep my hands on the steering wheel in the same positions
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
