some video from QR yesterday. Clubman and Sprint Tracks. Clubman is a fun little track, but Sprint still bores me to tears... the new surface is really good - no bumps in the turn 1 braking area and that giant bump in the middle of turn 2 is gone too. 9 tenths faster on Clubman than last time I went there a couple of years ago. Might go back in winter with my lower diff gears in to see if it can go a bit faster.
  • 3 weeks later...
I did the Mt Cotton hillclimb on the weekend in the 180SX. Bit dissapointed with my times, but it was only my second hillclimb in 5 years and I really struggled to get my head around it all again. Took me till the 6th run of the weekend just to get the first corner right FFS!
Had some front pad knock off, leading to a couple of rear brake lockups in the first downhill braking zone. So I was having to pump the pedal up with the left foot while negotiating the tricky exit of the first loop, nicknamed 'lover's leap' because of its sharp drop off - which was a bit distracting. I was still driving like an old mole through that 1st loop (in both directions) by the end of the weekend, so hopefully there's better times to be had by getting more used to the place again and pushing harder.
Still not sure which gear to use in the hairpin either. I recently changed from the stock 4.083 diff to 4.363 to try and help at Lakeside and QR, but I think it hurts at Mt Cotton. The taller diff would help make 1st gear more useable. Softer spring rates would probably work better at that low speed track too.
I got my best time on the last run of the weekend after a long delay for an oil-down in that first loop by a caterham three cars ahead of me in the queue - I took it so easy through there I couldn't believe I got a decent time! I ran two 48.1's on Sunday, but that's miles away from where I wanted/expected to be. To put it in perspective these are the times I've done in previous cars:
48.3 in a 145rwbhp L20 powered Datsun 1200 on A032R's
46.3 in a 300rwbhp CA18DET Datsun 1200 on nice soft Toyo RA1's
46.2 in my old R32 GTR - never dyno'd but only had Mines ECU, 0.9bar, exhaust and coilovers on puny little 225/50 R16 SR (hard) compound RE55S on stock rims. Would have been a rocket with some nice soft 255s. Shouldn't have sold it!
48.1 in the 270rwbhp 180SX was pretty dissapointing - only a couple of tenths faster than my old two litre Datto! anyway, here's some vid of me driving like an old woman around Mt Cotton:
Edited by hrd-hr30
I think I used the full url from the address bar at the top of the browser. Paste that into the 'insert media' button.
Got the split timing form Mt Cotton. The 180SX loses almost all its time in the first sector compared to my other cars. It matches the GTR in the second sector and there's just a couple of tenths in the third sector which I can probably make up, but that first sector is a bit of a surprise.
I remember the GTR being awesome of the slippery concrete launch pad, and would be better out of the tight first turn with its taller first gear and AWD traction, but 1.6seconds? That's a lot of time! The 1200 was very good off the line in 2nd gear as well with the soft RA1s, and very fast up the hills with 310rwbhp & 950kg.
At least I can see the car isn't completely hopeless around the rest of the track and know what I have to work on next time. Might make some changes to the car too...
went back to QR yesterday to see if the diff change helped. Beat my PB by 4 tenths, so I'm pretty happy with that. Here's a short 2min video - PB on 2nd lap:
Edited by hrd-hr30
My spin at over 200 km/h last Sunday.
http://www.youtu.be/scMvltta0Yk
bloody hell, not alot of room there! Got away with it unscathed though by the sounds of it?
Was the pedal slightly 'longer' than normal when you got on the brakes there?
Was it you who bought that front bar from a 33 I had?
I can see why you need it... Crazy!!
Yeah I think it was you I bought a front bar from. The GTR style bar with standard indicators. I did a test fit and other things grabbed my attention. Hopefully it will be going on in the next month or so and then I will be looking at an under tray with a small lip.
Not a lot of room at all and got away with it. The tyres are not exactly round at the moment.
Pedal was all good, actually my next run I did was only 0.064 secs slower than my fastest time of the day. So backed it up pretty good.
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
