Bernie and his kunt daughters can eat the carrot from my cable! I was pissed off when I heard about the camera gig. That wasnt explained at time of entry ... it helped me hide the pain of missing out.
Portimao was a great track. Better than Estoril and maybe just better than Zandvoort. It has plenty going on to keep you confused. It was harder for me to learn than any other track I have driven...though I suspect Bathurst will be a head warp for me as well. The lil R300 was so hard to drive straight....after some laps of throwing it around and losing it every secon lap the lasting fun was trying to drive it straight and get drive out of corners
If Iberia goes ahead again next year I am going to have to get the R32 over for it. Two days at Portimao in teh R32 would be epic. Would be a great track for a decent powered rwd Skyline
Hey Guys,
im always on here checking out peoples in car videos for motivation but have never pulled my finger out to put one of my own up.
This a 88 hr31 skyline that my brother and i race at supersprints and practice days. We managed a 1:07.03 with poor rear traction at the new south circuit at eastern creek.
(Note: dampers were wound all the way to hard rather than soft last track day so you can see its abit taily! has since been rectifyed!)
Has a Rb25 engine and gearbox, K sport big brakes and coilover, motec and fuel system plus HEAPS more.
Hope you enjoy the video! Cant get the youtube link to show the video here... just have to click the link
Edited by WAG.00N
Cheers! It should be abit neater next time!
I figured I'd smell the fuel leak before she ignites and if I don't it would e too late anyhow. But I like to keep it neat and tidy looking, even though I only drive it to the track.
The Marshall's definatly noticed a skyline sliding heaps.
Edited by WAG.00N
Alex, I saw you there on the ARDC practice day. Your car looks and sounds amazing :yes:
I was in the white Evo 6 and the good wife in the green Focus RS.
Thanks mate! Had a good day! We were watching you lift your inside rear wheel well off the ground every lap!
Quick question. I noticed your wife was in another group. We were In L2S group, what licence does she have?
Me and my brother both drive our car and paid 105 each. We asked the guys at registration if we could go in seperate groups so we wouldnt hve to share the L2S session but they were just rude an gave me no reason but "no you can't" and that you can't go in that group with a L2S licence.
So we had to share the session for the same money. Was not impressed cause it never been like that at previous practice days.
Any info would be good cause I want to make sure it doesn't happen again.
Cheers
on the weekend the WA CAMS Speed Event Series did a super sprint in support of the ARC rally guys on there Busselton Super Special Stage.
My day started ok but on my 2nd run i found out for real that concrete always wins.
Vid:
fixed it up and went out and finished the day.
Edited by racegtst
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
