Hey all,
I just got my car back from tuning a few days ago.
Its a pretty much stock r33 gtr, just with a power fc and an exhaust.
Its running 222rwkw @ 12 psi.
im getting around 420km to a tank driving sensibly and around 360 to a tank when i give her a bit of a hard time.
is this a good healthy result? power wise and economy?
what do you experts think :(
cheers!
https://www.sau.com.au/forums/topic/270342-just-got-my-car-tuned-r33-gtr/
  • Replies 75
Hey all,
what do you experts think :rolleyes:
cheers!
That sounds nice/healthy.
I get about the same as you, my mods are twin airpods, down, front pipes and high flow cat stock catback atm.
Stock +0.7 Bar (10.9 Psi) of boost.
If I really drive sensibly I can get 250kms just under half a tank, X 2 = 500kms, but I usually fill up when it hits half as half a tank last me about a week.
Plus you got an APexi Power FC which will help out with your air/fuel mixture.
hey, thanks for the info!
i've always wondered, are 32's lighter on fuel than 33's in general?
just curious!?
R32 GTR's are lighter, so there is less weight to push.
From memory I read this from some where...
R32 GTR = +0.7 (10.9 Psi) Bar Boost (Stock)
R33 GTR = +0.8 (12 Psi) Bar Boost (Stock)
R34 GTR = +0.9 (13 Psi) Bar Boost (Stock)
(I will have to check...)
So the more the R33 full boost, as apposed to the R32 full boost, the R33 will need more fuel as it is running a higher boost level.
But it's MARGINAL... So it should not make much of a difference but it will add up in the end.
hi all, thanks again for the comments and reassurance :devil:
here are some pics are requested -
apologies for the mess in the interior shot, i was sticking my turbo timer back on.
post-54322-1242660701_thumb.jpg post-54322-1242660756_thumb.jpg post-54322-1242660799_thumb.jpg
dude. that is dammmmm sexy. i love your instrument cluster ( nismo cluster ) i want that in white !!
awesome clean car.
Very tidy S3 mate, as for keeping it stock - yeah, right :(
With exhaust, front pipe, high flow panel filter in stock airbox and PowerFC my R33 just made 239RWKW, so power wise yours seems pretty much on the money.
No idea about fuel economy though, I just fill it up and go drive it some more >_<
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
