hey guys i bought a oil cooler and relocation kit and i was wondering what the best way to install it.
can i mount the relocation so the oil filter points up? if so should i crank the car over a few times when i do oil changes to get pressure?
or should i just mount the filter down?
also should i have it so the the comes from the block to cooler to filter back to the block? or other way around?
cheers
Put the oil filter relocator wherever it's most convenient, mounting it pointing up can be alittle messy when the filter comes off. If you are worried about pressure try a smaller oil filter like the Z445 (edit: seems the thread is different than the Z145a) I think it is, instead of the Z145a
Edited by Moodles2
ok arent you suposed to fill the filter and lines up with oil every oil change? would be hard if you mounted to filter point up, id rather it pointing up but if i had to fill the filter up everytime then id mount it pointing down?
yeah you do not need to drain the oil cooler every change. it's too hard unless your cooler has drain plugs fitted. if you do dran it simply remove cas or similar so you can crank the engine without it fiting. then lit it crank until you get oil pressure on the gauge. then your good to go. the twin oil coolers in my RX7 do have drain plugs on them though which is nice, but i've never seen an aftermarket kit that does. and the small amount of old oil in the lines and cooler is not a big problem. especially if you use good oil.
I never drained the cooler or lines either, ran one on my SR for 3years with no probs. If your not running a thermostat just remmeber in winter its gonna take a while for the oil to get to operating temp.
  • 5 months later...
if you loose a motor I personally would replace the oil cooler. you can have them backflushed but if it spun a bearing and bits of bearing material made it through the pump then chances are there is some in your cooler. It can be painful if it's an expensive one but is it worth risking the new motor? it does depend on exactly what happened though.
always always always replace the oil cooler, and also the cooler on the factory water to oil cooler next to the oil filter. $300 but you just cannot flush them out properly. As always I speak from experience in these matters :P
Duncan & BBaron if I ever doubt ya point me back to this thread
pulled the factory oil cooler thingo apart an well pictures say a thousand words they reckon
see now how impossible it would be to clean as well
oh well back to Nissan to hand over more hard earned
reckon I will pull all the sensors an stuff off an hot tank the base too
whats another coupla gaskets etc
always always always replace the oil cooler, and also the cooler on the factory water to oil cooler next to the oil filter. $300 but you just cannot flush them out properly. As always I speak from experience in these matters :blush:
You must go through a lot of oil coolers... :)
Priced factory cooler today now $420.10 according to my local Nissan
got a look at an rb20 today reckon the filter block looks like it would bolt up
unfortunately the owner of said rb20 wouldnt let me unbolt it to try it out?????
Just wondering if there is a recommend reliable oil cooler setup that is tried and tested for a 26, even it costs a little more? Given our dollar, a Japanese or even American unit would be reasonable I imagine?
The trust setup comes with a BNR32 arrangement: http://www.nengun.com/trust-greddy/oil-coo...andard-location
Or perhaps the PWR core with some custom lines: http://www.horsepowerinabox.com/HPIAB2/category82_1.htm
it is fairly straightforward to get rid of the factory cooler and bolt a oil filter relocator directly to the block. a lot cheaper when nissan want that sort of money for the factory bit.
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
