Haha yeh no problem there mate ;)
I would have thought people were referring to the actual upgrade... a de-tune was expected from Nissan anyways, probably a good 50kw down, nothing that gets factory imported in to this country comes in full spec. Its compensated for climate and harsh weather we get here as a precaution... :yes:
Really keen to hear the before number for sure, but even keener to to hear about the gain
  • Replies 96
Posted Images
Hey guys, just to shed some light on the power figures, the kW figures at the wheels of the Oz Spec GTR R35 reflect actual advertised engine kW figures so no probs there, its just that the Jap Spec cars are definitely higher & have approx 20-25kW more at the engine from the cars that we have dyno'd so far.
Obviously this could be coincidental that we happened to get a couple of really good Jap Spec cars and a couple of average Oz Spec cars on the dyno???
We will keep you updated and post the dyno figures soon!
awesome, thanks
with respect i think people are referring to this:
"After running the car on the dyno it is evident that the Oz Spec car is de-tuned compared to the Jap Spec version."
Obviously the car has been on the dyno for a baseline run and the number was apparently something of a surprise. It was brought up and people are interested, where's the problem? If it can't be revealed that's ok, bit of a tease though! :)
Hi Duncan, Yeah Jim, (CRD) the 35 & 32 are similar down the straight at E/C and most blokes are getting real excited, some standard figures would be appreciated? but make them await your forecast figures to give us more time with 32, thanks
The Beast has Woken!
Here are the results of the the HKS GT570 system we have installed on a R35.
Soon we will post pictures & a video link for all to hear the magnificent sounding BEAST!
Well done guys...top stuff.
Let me guess...the owner of this car is E.B. ?
  • 2 months later...
Hi there,
We finally got our COBB PRO TUNER SOFTWARE in, along with our customers GTR R35 for a custom reflashing of the ECU.
Results were fantastic with the car making over 380kW at all wheels which is awsome considering that we are still running on standard injectors.
The larger injectors have been ordered and with further programing we should be able to dramatically increase mid range torque going by the initial test results on the chassis dyno.
Generic & custom mapping is now available from the tuning shop that made the NISSAN GTR the cult car it is today in Australia, Croydon Racing Developments!
We will keep you posted on further developments.
Nice results...but
I cant help myself. CRD gave the GTR its cult status in Australia? :D LOL i am not sure, but based on the amount of Suzuki GTIs you used to do back in the day i will pay the fact that you made those the cult car of the early 90s :P:D
Again, good work on the results! :)
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
