..... isn't the manual rated lower than the auto too? Anyway, isn't the 6 speed auto much better suited to the car, even unladen?
I don't see the logic in towing with an underated tow vehicle, crash it and no insurance for anything, bye bye to both vehicles.
The clutches in them do not cope with towing, even with loads under the limit (mind you, the 1600kg limit is for a car with a 65kg driver and nothing else on board) stick with the auto's with the heavy duty tow pack and they are Ok.
Bingo!!!
Also, something that most people don't know is that if you're towing more than 2000kg, then your trailer must be equipped with brakes on all 4 wheels, and must also have a break away system fitted (so that the trailer brakes automatically apply if the trailer becomes disconnected from the car). Very few car trailers have this unless it's specified as a 2500kg (or more) trailer. That's why you'll see the load rating on all car trailers as 2000kg TOTAL.
I haven't read the wording lately, but I believe that the 2000kg refers to the total trailer mass + the load on the trailer - the downforce on the tow ball (normally about 100kg or so). Note I haven't double checked for a while, so that last bit may not be correct. Best to determine for youself before committing.
The auto Falcons used to have a higher towing capacity than the manuals (in the days of the EL, anyway). Don't know if that's changed in recent times though.
Many modern 4WD's have piddly clutches that aren't really up to the task of regular towing. In the name of making the 4WD's more user friendly for their intended purpose (soccer moms, etc.) they have lightened a lot of the controls by fitting more car-sized components. My PAthfinder will quickly smoke the clutch while towing if I'm not careful, although after 75,000km it is still going strong.
they shoulda stuck with the power assisted clutch like my 88 GQ TD42 has instead!
What the hell is wrong with heavy clutches anyway? My wife hates these modern light clutches as much as I do. We both loved the heavy clutch in the GTS2 we owned many years ago (was a heavy sumbitch, but great feel - the clutch that is, not my wife :banana: ). all others since then have felt like shopping trolley clutches - very disappointing.
I've been towing my 1200kg car+trailer abit lately with my brand new Holden Ute SS-V and love it. I put the cruise control on the speed limit and it sits on it the whole way everywhere I go. When on a flat road it switches the v8 into 4 cylinder mode and I can do 6L/100km whilst towing.
IRS :)
Changed how many rear tyres Ben ?? The IRS on these is a JOKE. My mate had had 3 sets on the back in 50K
Only Commodore/ute that can really tow properly is the VZ Crewman crew cab which has a live rear axel and 2500kg towing capaity. Preferably with a V8.
I have a 6 cylinder one which is marginal/good for towing a car but is great otherwize.
Having said that. You will prob not have an issue cause you car/trailer is so light. The massive trailer and the zed on it where pushing 2000kg. It was a very long trip from QLD.
Edited by Tektrader69
yeah thanks for the comments. I really want a manual and i know that it's rated at less but I'll be getting an aftermarket heavy duty (2000kg) tow bar. will prob wear out the clutch. I only tow every couple of months so hopefully it will be ok. Gotta be better than my VS SS.
I've just read on the ford forums that they flog out tailshaft uni's. Might need to beef up the suspension so it's not dragging on the ground.
I really don't want an old 4WD. They may have the weight to make it legal to tow with but they're slugs. and uncomfortable.
Well my trailer weighs 700 and I'll say my gtst is about 1300 :cool: so I just scrape in under 2000kg.
so you plan to exceed your towing capacity by at least 25%. good idea, what could possibly go wrong?
and your biggest concerns are clutch and unis? legality, safety and insurance don't even rate a mention.
I wish cops actually targetted real safety issues like these rather than putting speed cameras on highway on-ramps...
Sure you can put a two tonne rated towbar on it, but it doesn't mean it will be legal. If the manufacturer states 1600kg, then 1600kg it is.......
(as an aside does anyone know if the legalities of towing still vary massively from state to state? I remember many years ago it was always a drama when towing our 7 metre Sharkcat into NSW because the rules changed dramatically)
Well I've towed the same setup on a 1200kg tow bar coz I didn't have anything else.
I know it won't be legal but I'll pay the fine. I think it would be over engineered and 1600 is conservative. Manufacturers would have to be on the conservative side.
Back on topic, a F150 LWB with 351 on LPG makes a great tow vehicle.
Yeah but would be a pigg to drive around.
I've towed far in excess of legal and manufacturer's limits too, the point I am trying to make is now I'm older and smarter I certainly wouldn't be risking (for arguments sake) a 40k tow car, a 30k race car, and a 4k trailer being totally uninsured if I was to have a major accident, keeping in mind if you run into another car and hurt someone, no insurance there either.
Bought it new and only put 3500km on it so far in 2mths with 1500km of that done in 3 days (towing) so haven't had a chance to wear out the back tyres yet, besides it only gets driven 50-100km in a normal week so i'll have traded it in before it reaches 50,000km.
The VZ SS Crewman has a lower towing capacity than my VE SSZ Ute.
My trailer is rated at 680kg and my car is 560kg so 1240kg all up and usually around 150kg of tools n stuff in the ute tray. You have to look in the rear view mirror and see the car on the trailer to remind yourself that you are actually towing something.
My previous tow car was a 2000 Toyota HiAce 2.4L Auto with 85kw and 200nm (probably 65kw coz it had 350,000km on the clock) that thing struggled just to tow the trailer over speed humps.
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
