So my 2011 d40 navara tows great, good economy and all, but new house has a steep thin driveway i wanted the trailer loaded at the top, heat warped the dual mass flywheel doing it, lesson is dont reverse 2t up a hill slowly, you have to ride the clutch a little to control the speed and it heats up the flywheel... So its new clutch and single mass flywheel time already...
Tip from clutch guy i spoke too, reverse in 4lo even on concrete and all will be find and easier to control speed rather than having to ride clutch a tad...
$2k for new clutch flywheel fitted, bugger
That is a great old 4WD trick - to put it in Low Range whenever you are going to back a trailer up - no clutch slipping is required and you can easily move a loaded trailer into a trickey spot or up a steep driveway.
Which is why auto TDI tow trucks rule. Had a manual pathfinder, swapped for auto and would never look back. Race and rally cars are for fun so no need to stuff around with gears in the tow truck as well (despite my posts in other threads saying autos are ghey. Ignore those comments for the purpose of this argument)
Only possible if it's an old fashioned part time 4WD with manual locking hubs. It's the main thing I missed about my old Patrol.
If you have a part time 4WD (with transfer case) and auto hubs, this will put it in 4wd and you risk binding the transfer case if you're turning while reversing the trailer. D40 is in that category, so selecting 4L and reversing is not an option if you need manoeuvre the trailer at all. Unless there's a pov spec version with manual hubs?
And constant 4WD things (with center diffs) normally only go to low range with the centre diff locked. Again, this risks damaging the driveline. Low range reversing not really an option
Edited by hrd-hr30
The cruiser locks the centre diff lock when in low range... Makes it a pain in the ass! I found there is a way to disable it but i cbf...
I guess this is as good a place as any to ask...
We're contemplating an 80/100 series Landcruiser, which we'll probably keep and run into the ground. It'll do a lot of medium-distance towing (600km round trips) and eventually be a farm hauler too, but will probably be the mummy wagon from time to time. Since I'll be doing all the maintenance (and hopefully mods) myself it needs to be relatively easy and simple to work on. Is it much of a drama to work on the 4.2TD models? Also, is there any downside to the 1FZFE petrol engine other than going through fuel like there's a hole in the tank?
Wihle I'd love to go for a TB48-powered GU Patrol they're like hen's teeth over here and highly priced when they turn up.
Nothing wrong with the Toyota motors other than the petrol sixes valve stem seals.
The 100 series 4.2 turbo diesel is an absolute cracker!
This is what i want to upgrade too!
Heard first hand from a bloke who has a Toyota V8 diesel from new, fuel system failed at around 130k, cost him something like 8 to get it fixed. Toyotas are not what they used to be, particularly the diesels.
When I was working for Nissan last year I borrowed one of the STX550 Navara's to punt a car trailer around with the old GTR on it. With the 7 speed auto and the power and torque from the V6 3 litre turbo diesel it drove the same as when it was unloaded.
Now I just have to buy one dammit!
I was wondering why they only have a towing capacity of 3T compared to other cars with less NM that have 3.5T... We looked at an ST550 and it didnt look all that exciting! Would be nice to tow a nissan with a nissan though :P
  • Like 1
Towing capacity has about 13.75%(*) to do with engine power / torque and 86.25%(*) to do with vehicle mass / stability / chassis rigidity. A 430kW / Zillion NM HSV GTS has a lower towing capacity than the Navara
*Percentages for illustration only. Actual results may vary.
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
