Yeah I would have to say that heading up the big hill coming out of the gong is a struggle for any car.
Up mooney mooney I can sit on 100 if I really want to but I usually do about 80 to 90 up the hill.
got to love the falcon
I'm talking all the hills on the F6 from Wollongong to Sydney, not just climbing Mt Ousley.
on the BA manual, beware of redbook, not all of its figures are accurate. From memory when i was researching all manual ba-fg xr6t had a 1600kg towing limit. Clutch and box don't like the strain.
also, i much prefer the having a lot heavier tow vehicle, just imagine what its like pulling up a 2.3t trailer with a 1.5t car when the trailer brakes fail.
or even worse even if you're halfway around a bend and you need to slam the brakes, chances are bad enough of jack knifing with a 4WD, youre nearly guaranteed it in something like a falcon or commodore.
  • 11 months later...
4wd all the way
if your trailers and car are close to your tow limit just add fuel and tools and your well over
not worth the risk
Sorry to bring back an old thread but i couldnt help but think how funny fatz is talking about safety. If i remember fatz car trailer was the thing of ledgend for being so damn dangerous even the tyre rack fell off one time and i had to weld it back up.
Mmmm death trailer was the reason I got my first 4wd
As a upthedatefor this thread
Q7 approaching 200k on the clock
Still tows like a mofo..loves 3 tonne out the back
Do recommend and for the f**kers above I think you can pick one up for 20k now
I must say I have been eying off a few v12 q7s as a upgrade recently
Why not the V10 Toureg, and pocket the massive difference in change? I've driven one of those towing a big arse trailer. Was like nothing was attached to it.
Excuse ignorance, but much difference between them?
v12 has 500hp
Have owned QE7 and TOUAREG V10, both very capable, V10 noise under load like rolling thunder, main difference besides size is that if you venture off road into slippery stuff , the VW will be pulling out its sister. Haven't driven V12 so cannot comment.
For under 20K I love my 4.2Turbo Diesel Cruiser. 2000 model.
Not quite as quick as Fatz pram, but if you do go off road it goes pretty darn well :P
So well that I sold the car trailer I bought to tow it so I can 4WD more instead :P
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
