Just now, Hank Scorpio said:
Or if you enjoy punching the underside of the dash with your knuckles ever time you put the handbrake down.
That's quite a specific requirement but you gotta go with what works.
I have not looked back since getting a Audi Q7. Can tow car, trailer and several hundred kilos of tools, fuel and 3 mates like most cars going to shopping centre.
A good 10yo one is now probably under $35k.
  • 4 weeks later...
  • 1 month later...
Oil change every 7.5k $150
oil and filter every 15k $300
new rotors every 50k $500
pads every 30k 250
one satnave in 300k $1000
power steerin 1.5k
blower fan $400
new battery $550
water temp sensor $50
also did diesel pump belt and water pump at 200k ( this didn’t need doing but fingered I was in it for the long hall)
Every 100k gearbox and diff oils 1k
tyres last 40k(rear) 60k front
1 minute ago, ActionDan said:
Excellent info, much appreciated.
It's a turbo diesel right?
So when are you expecting turbo/injection pump to shit the bed?
Trans still happy?
Updated above post
still going it’s due for new oil at 330k will report back then
So the big ticket items are still to come.
I assume it's got direct injection as well so 6 very expensive injectors + injector pump is a good few K (same as any modern SUV now), turbo will be whenever it goes.
200 if you want to go off-road
q7 tows as well but much nicer when not towing
which is 90% of lyf
landcrusher always wins on resale cause Toyota fan boys but all the 50k landcrushers r 250k on the clock so just buy new as money wise it’s a similar depreciation
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
