Hey,
Just spoke to the guys at competition coatings, and they were telling me they silver coating isnt good enough for the rear housing, and they need to use the black coating, which is more expensive, and not as appealing to the eye. He said he has done a few in silver, but mainly for show cars, and if they get too hot they go grey, he said it doesnt look too bad. Just wondering if anyone has done silver, or got any pics of a silver one, thats gone grey.
cheers
Edited by choku_dori
https://www.sau.com.au/forums/topic/273287-hpc-coating-turbo-rear-housing/
yea normally the coating will go powdery and come off a bit but it stays a duller version of the colour you put on most the time... make sure you get it blasted or acid cleaned before you do it though otherwise its a waste of time.
personally anything that is getting a bit of surface rust like exhaust manifolds or whatever i just dip/spray it in phosphoric acid which chemically turns the surface black/gray and it stays that way.
phosphoric acid also works really well for brightening/ cleaning aluminium and is allot safer than the hydroflouric/nitroc acid mixtures.
  • 3 months later...
just to double check that is basically what Rust Converter is right?
Well the silver Comp coatings is using is good for 1600oF - they should know well enough that they can use a special primer to raise that threshhold up to 2000oF to match the blacks rating.
couple of hints :
-clean hands and no oil on the parts before using it for the first time will ensure maximum shine
-you can repolish the chrome coating with metal polish, just remember to use methylated spirits to clean off the polish residue before starting the car up again
I use the same products that they are listed as a distributer for - Leon if you want some extra info chat me
Any idea what it would cost to do an ehaust manifold, one piece split dump and exhaust housing?
No chrome tho, just a factory looking grey or black.
Edited by W0rp3D
    • The team at OBD2 Australia are pretty good, shoot them an email and ask them. I've dealt with them before for work stuff. I'd be shocked if it didn't work, so long as Consult can activate the ABS. But you might need to use KLine for it which would be the stopper, as I don't think that piece does KLine comms.
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
