My car is being prepared to CAMS 3E (Production Car) regs, the same as Mark's car.
Basically it has to run no more than the N1 spec, so n1 turbs are ok (but out of my price range so I'll stay stock), brembo brakes, upgrade oil and water pumps. Suspension, exhaust and puter are unrestricted. Tyres are no larger than N1 spec (245) and have to be yokohama A032rs. Pretty basic spec really :P
  • Replies 74
Basically it has to run no more than the N1 spec, so n1 turbs are ok (but out of my price range so I'll stay stock), brembo brakes, upgrade oil and water pumps.  Suspension, exhaust and puter are unrestricted.  Tyres are no larger than N1 spec (245) and have to be yokohama A032rs.  Pretty basic spec really :D
OK so it is a N1 spec GTR with bigger turbo's. Do you know what power it makes?
Duncan are you geting or have a GTR now? Marks car, who?
Give me a call when you can.
row row row your boat gently down the.....................
Sorry, wrong thread :D
The GTR's are coming for you John
Good I hope they do as too many shoulda guna meetings. I hope to see more out there, not just beer talk.
Gary Burchet who owns three R32 GTR's and put the best of all three into his Targa GTR. He is very keen to rub my nose right in it, at our next track day. It is N1 spec and he has a Hollinger sequential in it so should have a big go.
Big target on my Slot Car.
if marks r32gtr n1 can peal of a low 47 imagine what it could do with some slicks???
what is happening to your gtr druncan i hope you left it in some good hands lol
lolololololololol
and the r31 is on the road so it must be time to find my kaggs and go for a drive
pete
yeah, I picked up a cheap 91 gtr to race, fatz is currently ripping it to pieces to race prep it. Can't wait to get it out on the track, I did 3 laps in Mark's car the other day and it was beautifully balanced.
Mark Hawkins has finished prepping his car, thats the one I'm talking about, its racing in combined touring in the NSW champs this year as well as having a shot at targa. No n1 turbs at this stage, just the stock ones.
Its great to see some competition out there John, keep stirring everyone up :D
now thats really funny :wassup:
If dodgy Mcgill can get his act together and finish our stage 3/cams testing, another GTR should be out around May to have some fun.
Duncan,
Do they have a class of racing for crap drivers with modded cars??
lol doughboy, I was going to say Supercars :D
TrustGTR if you're serious about giving it a go, its really easy to get started, super sprints are cams organised trials around a track, results are based on your time compared to other cars in your class. Thats what we ran in last Sunday.
  • 4 weeks later...
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
    • 310mm rotors will be avilable from Australia, Japan, and probably a few other places. Nothing for the front can be put on the back.
