  • 3 weeks later...
i had to reformat my ps3 today. reinstalled gt5 (twice due to it being stupid). then had to download all the updates. fuck me that was a pain in the sphincter. about 2gb to download all of them. after downloading and installing half of them an error occured. even though it had installed 5 of the updates, because of the stupid way it does it, i had to start all over again. 2 of the updates that it had already installed were 608mb and 1192mb, which it had to download again. so it took about 5 hours all up to install and update. really wish they would allow you to download the game updates on a pc to the install via usb, like you can with system updates. would mean that you could just download each new update as it gets released and then if you have to reinstall the game you can just plug in a usb stick and apply all the updates from that.
cant say ive had an issue like that.
When switching consoles from my old YLOD model to my new one, it was a simple transfer (after getting the old one running again)
otherwise the only time ive had an issue of it dropping out is on my brothers PS3, when we installed GT5 we also had 4 other comps interneting at the same time and it had a little error in the last 3% of the updates (all of them):angry:, but it had only forgotten about 300mb the next time round. so no big issue
i feel your pain, just spend the last 6 hours ridding my PC of a virus, and attempting to recover lost data.
completly ruined my GT5 session, was half way through a dam race too >_<. but almost done, i'll be online racing for quite a long time tomorrow
so drop into the room and have a few races if you guys are bored. i'm usually in the Japanese GT300/GT500 rooms
i have it drop out all the time when doing updates over wifi (router boots it off. router is a piece of junk. restarts itself every few hours). this time i had it connected via ethernet and it was when it was installing one of the updates that it got an error, not a connection issue.
New Dlink router with Wi-Fi less than 100 bucks!!! win. i had to replace mine recently due to a lightning strike (which also fried the Network plug in my Comp :( )
Coincidence! My router got fried by lightning strike last Friday night and then was pronounced dead on Monday.
On the plus side, Harvey Norman have 30% Cisco stuff at the moment so I grabbed an X3000 which is performing very nicely :)
  • 9 months later...
I know the new Vette is now available on a DLC pack, if that's your thing
I'm keen on finally getting the Spa circuit, and adding the Aventador would be good
But need to do my first ever system upgrade on the PS3 in nearly 3 years beforehand... as soon as my data allowance rolls over for the month, lulz
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
