you forgot about the part..... and not double clutching like you should.
It's 60cc within the boost-able range for the ADR's and well within for NSW regs for the original weight of the car. i still think an AWD supercharged VH45 R34 GTR needs to be done Sean, come on you know you want to! despite the fact the maximum engine na size for a r34 gtr is in the range of over 7litres.
for all the peeps out there: for cars over 1100kg you can get the maximum allowed na engine size by multiplying your cars original tare weight by 4.4 for ADR's and 4.82 for nsw regs. these figures are lower for turbo engines.
e.g an 1100kg car can have an na engine of 4.84 litres for adr's and 5.302 litres in nsw.
this means you could twin turbo an ls1 and put it in your r33 Matt. hint hint.
The engine bay and wiring was already being prepared for a 6.0L ;) ;) ;)
Unfortunately, dollars are winning... unless you find me a 5.7L manual wreck for cheap and we'll get Sean to swap that in instead... ;)
I would much prefer the 6.0L though... So keep an eye out for those too... (Yes, I'm deadly serious)
Somehow worked out how to do this on a mobile...
I've tried everything to try and get the windscreen wipers to stop making that noise. I'm thinking crazy clean with some alcohol or rainex it.
I'm pretty sure that godspeed s14 has cams and drag radials on that 11 second run.
That's 570k ohm resistors, one to replace each knock sensor. As long as high octane fuel is used, there should not be any dramas.
Put it this way, it will get to 80km before a 300RWKW R32GTR comes onto boost in 1st gear from a normal standing start, (not launching!).
Oh, and I vote that Farch at least runs it down at WSID to see what it runs!
All that work on the conversion, and it has squeeky windscreen wipers... :P
yeah squeeky windscreen wipers add 100HP...
but yes he should take it down the strip and remove the back half of the zauuust then people from about 50km away will hear this beast!!! I found that it has the same snap your neck feel as sloanes car does on boost... but this is instant!
80 km before a 300kw gtr even comes on to boost, I like it already. And I will run it down wsid and see what it does with a standard vh45de. Hopefully it does better than the 13.9 that the ca18det did. Also Hope to get better than 300 k's to a tank when it's using not in the knock map. Already got a name for a guy who does rollcages in mcgraths hill.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
