i rang camtech in Sydney they told they are willing to to a regrind for me, i just have to send a set of cams down to them so they can see what sort profile they can do. now i just have find a second engine.
  • 4 months later...
  • 3 weeks later...
Lol. I sold them to him from my car. He was a bit iffy at first but in a short time he loved the look :)
yeah, it seems everything gtr was made for a 180sx upgrade.
since the brake and driveline upgrade, i've bought a second engine that had water in one of the bores to make the cams with. i since spoken to kelford cams in nz who where more helpful than camtech. kelford said they would test the cams for defects and then make a decision of how much they can grind them and to what duration. where camtech said they don't do that and i must tell them how to grind.
i'm also going to use the second engine to test engine internals from other cars to see sr20 rods fit and that the arp rod bolts and head studs fit and if sr20 cam cap bolts.
If your going na power, some guys in the states are looking at going with Honda rods and motorcycle short skirt pistons.... Shedding kilos of rotating mass. Might be worth looking at?
... On a serious note though, Jim wolf have done a lot of testing with vh cams.
Are we likely to see some short velocity stacks under that cowl? Maybe a little gas?
J.
got the old r32 brake master cylinder replaced today, swapped with a brembo spec r33 gtr master.
top one is the old r32 spec 15/16 bore and the bottom is the installed brembo r33 bm57 1-1/16 bore.
pretty much instant braking response now, just have to worry about the daydreaming idiots behind me now. (well...more so)
One of the SAU Traders Halfod Motors has new BM57 (e.g. 17/16 bore) master cylinders in 2 and 3 port models for $149 and $139 delivered free.
This is much cheaper than buying a second hand one and then trying to get a kit to recondition it
Thanks Charles,
I pretty much came to that conclusion after my own searching tonight! The BM50 would probably be better, but runs a hefty price as a non abs.
Being a rps13, mine has a bm44, so it's better than the early models bm33, but I don't think they are up to the brembo fronts and twin piston rears.
So I think I might give the 57 a go- cheap and easy to get in Non abs.
Actually splits the port via a tee to both front wheels, rear is single line to the back and splits at the back :D
So bias is set as per factory for front to rear.
He just needs to source a new connector plug to suit the BM57 reservoir (as they are different manufacturers) so that the low level warning light works.
  • 3 weeks later...
yesterday and today we started doing some over due maintenance on the vh45, new injectors and replacing the leaking rocker cover gaskets. the old injectors were so old they gone white, this should make it run smooth as silk.
new injectors, nissan wanted upwards of $400 each for them i managed to buy them on ebay for $400 total from america
one of the new injectors was dead, not happy but at least it was number one cylinder and can be removed with out taking off anything else. We put one of the old injectors in instead, luckily it seems we managed to find one that's not miss firing. ordered two more to be safe.
I like how u say we, when its really just sean :P
  • Like 1
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
