  • Replies 417
Things you need for DECA:
-Stamina/Endurance
-Concentration
-Good handling skills
-Remember where you need to go and how to get there (follow map if need be)
-No need to stay in a straight line
-If you lose control, put on a good show for those watching
-Have plenty to drink
-Stay away from the cones
Things you need for DECA after party:
-Stamina/Endurance
-Concentration
Just what I learnt from my first DECA back in may... BrendanR33 :thumbsup: ---> :) ---> :thanks:
So have you fixed your cable from popping out ? or is that zip tie we fitted still doing the job ;) its good to see you come back for another go, see you there.
And juliette, wining by default ain't cool !
ATT Ryan, can you put, Vince Ritchie, David Talbot, Karlos Broulidakis and Daniel Garber in the same group, thanks. oh and i'm still bringing my s13 silvia as previously planned. :(
lol cable tie is still holding my throttle cable in place :( hahaha im lazy as.
Will the CAMS SAU Membership card sufficient to enter for the day, or will I need to produce/fill out any other licence forms as this will be my first outing?
You will need to get a CAMS L2S licence. You can download the form the cams website, fill it in and bring it along with the payment to Bec on the day and she should be able to sort you out ;)
Re the CAMS license, what Anthony said^^ is right
Also - anyone who posted group preferences or anything important in the last few days, it may be deleted - have a look, if its not there, repost it, or we wont know.
Thanks
Thanks
well, the only people on sau i have met who are going are Roman and Juliette, so if you could chuck me in their group that would be tops thanks.
Thanks
Leon and Shane in the same group if you could.
They are bringing a couple people to watch... :rofl:
Fixed my clutch pedal today since it broke on the drive home from winton. All good to go.
More importantly this will be the debut of our new trailer! After months of work it will be finally put to the test.
Good work Mat, Tim, Campbell and Dano!
Can't wait!
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
