"I'll be converting the Crownie boxes to Alloy soon"
I'd love to see that magic trick... actually I'd like to see that magic trick in reverse! ha ha ha Alloy is cheaper than beer...
I cant wait to see the intake... If it works out well, I'm totally going to plagerise... ha ha
J.
  • 3 weeks later...
and in other news damo has been seen in the bushes around primary schools.
I've had a paint sceme in mind for a while now... and it's not painted like an animal, cars painted like animals look stupid, dad proved that.
Aw come on ben, not even something like this?
It's hard to get motivated when it's cold. I measured the suspension up today. Rear is easy to get good travel on. The front doesn't have alot of room for travel, you can only get about 60mm of travel at 345mm ride hight before the upper arm goes through the top of the tower. I'll reserch and play round with the ride hights on paper before i order the shocks
  • 4 weeks later...
Now got job security, so it's back into the car.
I've ordered my air filters for the airbox (2x Merc 600SL), and a 044 to pump E85 goodness around.
Damo wired in the ABS this weekend
I got 3/4 of a alloy donut and started my intercooler piping on the
It's almost ready to weld, I didn't take pics of the last section, but it just needs the ends tidied up, then off to the welder.
Also got the seat mounted
ben beat me to the pics but i thought id add some more pics to assist with other people wiring cars.
I use deutsch plugs for most of the bits that need plugs. these are by far the best plug you can buy. weather proof and higher current carrying capabilities than other similar sized plugs.
this is how they go together as such. this example is a plug for the ABS wheel sensor. the wire is 16gauge Mill spec is in PVC sleving which is my profered looming material. it makes the nicest neatest job of any loom but is a pain in the ass to do and probably adds 50% more time to any job.
next ois what i started with regarding all the ABS wiring
this shot shows that there is 2 looms mearging into one. a pice of heat-shrink is then slid over the top and once the 3 bits of PVC sleving are pulled into one the heat-shrink is then heated forming a seal between them all. On engine looms i use doubble walled heat-shrink that has a glue inside of it. when heated the glue goes runny and the heat-shrink pulls tight making some of the glue ooze out the end. this give an almost water tight seal and prevents the PVC sleving from pulling apart over time.
ill get a few more pics in the next week or so of the wiring into the switch pannel and fuse boxes.
I made the turbo side piping today. it's almost ready to weld up, but the pipe that damo supplied wasn't long enough...apparently this is a normal occerence. Another 50mm or so of pipe should fix it.
Got some sensors for the Haltech (oil temp, oil pressure, fuel pressure, exhaust temp)
Air box MKII with one of two filters in. pretty much a copy of the GMS one. Need to get some alloy and make it now, and then design the top 1/2.
Got the intercooler piping ready to weld today. Took ages to file all the joins so there wasn't any gaps... welder says it makes his life much easier.
I got a surge tank during the week too
  • 3 weeks later...
I got some more work done on the weekend
I cut the airbox out, and bent it up ready to weld.
I installed the Aero catches. They are are pain in the arse to install, but it's worth it when there in.
Also installed the belts, and finished suiding the interior
I got a heap of speedflow fittings for the surgetank setup.
I'm putting bulkhead connectors in the floor or the boot, will make it neat, and i won't have to worry about hoses rubbing on the hole in the floor
I'll get some hose tomorrow now i know the lengths, and then the setup will be done
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
