Well i have been looking for a number of months now and have missed out on a few in the 3-4k price range. My mate found this car at our local wreakers and i thought what the hell i sould be able to get it on the road for the cost of those other cars but i will know whats in this one.
Frist day i got it, we got it running in about fours had a blocked fuel line.
So the next day i went out and brought all the filters and oil to change it all.
It didnt like the new oil as it sounds like it mite have sun a bearing. Not that this worries me much the motor was coming out anyway now i will just do a full freshen up and know what i have there.
Here are some pics i took today inbetween the rain
You can see the small tear in the drivers seat that and the badge missing on the drivers door only bads points inside the car.
So that brings us to the bad points the rust i have to flamin mongrel out and sand back before a respray
You can see someone fixed this guard before with bog and didnt do a good job
Normal bonnet thing
Surface rust on the roof.
There are a few offer things to do like the fuel cap dosnt close looks like its missing a piece to it but this is where it starts i will post up photos as i do things but this is a slowish project. Will be getting fender mirrors and a front lip i think too.
Going for something like this lol
https://www.sau.com.au/forums/topic/278602-240k-project-4dr/
For a daily driver the 240K still does well. I used one 'til recently for getting around Sydney. 34 year old 240K still more comfortable than a 2003 Hilux :rofl:
Here's a bit of inspiration for ya! I add more as I find 'em.
Edited by 72GT
So i started some of the stripping today.
Only down side is the Passanger side guard is as bad as i thought tho the damage was not as bad inside as it could have been
And i have started to paint the wheels back to black aswell.
Am going to pull the seats and carpet tomorrow i think if i can find some where to keep them.
So i did today what i have been putting off i went and checked for rust where i though i would find it and some spots i didnt know about.
The rust i sort of knew about
The suprise
This is thanks to someone at the wreakers not closing the back passangers door right
this is what it would have looked like if it didnt have that slow leak from the door
Well thats some of the bad bits now here are some of the better things
Originals
Original keys
So looks like i will be pulling out the windows now to see the how bad the rust is there too.
NOTE:
You may have noticed this thread has been moved.
SAU Admin have decided to run a new section for "Projects, Overhauls and Build-ups"
As such your thread is a prime example of what we wanted to house in this section.
We have left links in the sections you originally posted also to allow easy access to the threads new home.
Any issues, please feel free to pm myself or N1GTR.
Cheers Col
  • 1 month later...
Well things have slow down i decided to fix my GTR so not much has been happening on the Datto.
Engine and auto are out tho.
Engine Crane
Took the motor out frist
then decided i wanted the auto out too
plenty off room now.
The reason for the water leak this is the thermosat housing and hose which looks like it was just all stuck together lol
This is the product im coating the car in to fight off rust.
mate if u ever need parts pm me i have a few 240k's and heaps of engine parts i mean heaps of engine parts. use to go threw these L series engine on a monthly basis haha lol
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
