Hey Has anybody had much to do with MPC in Bayswater?
I was thinking about getting a Service done there as it is close to my work?
Just wanting to get some opinions as to what are they like there do they do a good job etc etc.
Cheers Ben
https://www.sau.com.au/forums/topic/279760-melbourne-performance-center/
Racepace Motorsport
9/6 Holloway Drive, Bayswater
Ph: (03) 9762 9421
http://www.racepacemotorsport.com/
If you work in Bayswater and own a Skyline and need work done.... it's a no-brainer.
People come from all over Victoria (and some even interstate) for Ben to work his magic. He works almost exclusively on Skylines so knows them inside out. Just give him a call and tee up a time.
Racepace Motorsport
Ph: (03) 9762 9421
RACEPACE
Each time I get a service and or work done it is a 2 hour peasant wagon ( tram train )trip each way..... two hours after dropping it off and then two hours to get back out there when it is ready... ( from Port Melbourne )....
Would not even consider taking it any where else but there.
Edited by racin8
  • 6 months later...
Well MPC is more like race related workshop, they do Australian gt championship cars and as for skylines. They know what they are doing man. Not the cheapest, but is you want your car serviced by the race specialist, I'll take me car down. I know them well coz I make all their lamborghini racecar upgrades parts in carbon. Assure you they are not street entry level.
take ur car to electronic automotive in epping to my r34 gtr there amazing work
Engrish??? :D
The guy is thinking about travelling 50m to get his car serviced, not 50kms.....
I say do a search on the above mentioned workshops and see what people have to say about them.... :(
What's the deal with so many tuning shops being in Bayswater? I think there are like 8 places all within 500 m of each other.
Racepace, Techsport, MPC, Nizpro, A to Z Tuning, RA Chapman, Dynomotive, Advanced Engine Management.
Not to mention the 101 parts/support shops in the neighbourhood. Maybe they designed those few blocks with car tuning in mind, and everyone just congregated there to save money on transport.
If it weren't so friggin far away I would move there. It'd be awesome knowing that whatever car I will ever own in my life, I can be pretty sure one of those guys within walking distance knows how to tune it with parts available next door, and tune it well :D
If it weren't so friggin far away I would move there. It'd be awesome knowing that whatever car I will ever own in my life, I can be pretty sure one of those guys within walking distance knows how to tune it with parts available next door, and tune it well :)
LOL, was thinking the same thing, most of the guy's know and have learn,t off each other very well, still worth the long walk, the bus, two trains then another walk for me. :)
  • 5 years later...
I only use MPC for my drag Supra. They do almost everything in house.
Tony is one of the best tig welders I've used and can make anything out of any metal. Roll cages, custom mufflers, brake ducts, anything !!!
And dyno tuning Lee Burnley is the safest most reliable tuner I've used. They have a 4WD mainline dyno that I strap my 1000rwkw supra down to and has always got the most safest fastest spooling tunes the car has ever made. Plus they also have everything to make the tune full EPA legal to pass emission tests.
This is the only all in one race shop I trust.
They only employ the best staff one of which is ex v8 supercar engineer who is a true genius.
Give them a shot, you never find a better all in one shop.
-Darren
Not a fan myself - took a Soarer there to get a flat spot and general lack of power diagnosed - they put it on their dyno and said a dip (not just a plateau) in the graph was normal.
Also, since when did a tune need to be EPA legal? It's the modifications that the EPA/cops dick you on. Emissions tests are just part of the passing process and a stock tune can pass you. You still need to remove the modifications behind all your power.
  • Like 1
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
