  • Replies 340
Posted Images
heres how it sits as I type..new catch can can be seen on the beaver panel...still gotta figure out when it will fit. :)
I think the thead name should be changed to ...2015 MRA build...this is gonna take a while lol
haha yep....these things always take waaaaaaaay longer than you expect
Yeah...stupid cars!!!
in other news the car now has a great big bloody towel rack bolted to the boot...ill get some pics tomorrow, and my manifold gaskets should turn up tomorrow...so hopefully it will be running again on the weekend :D
I'm liking this VERY MUCH!
Let me know how you find the new turbo, as I want to pull my turbo + mani off soon and replace it with a bit of a smaller turbo, purely to bring boost on sooner... Thinking a GT3076 or GT3540... (On the 3L)
That's if it holds together on Thursday!
Going to use the 25det head ive already go.
not going to do much to it, just clean the ports up and whack in some new stiffer valve springs.
1... Throw that idea in the bin.
2... Sell me your 25 head and forward facing plenum.
3... You go buy a 26dett head.
4...
5... No profit, but lots of win...
As for my turdbro...
Ignore my engine bay, as LOTS has changed since this pic...
nah i wish lol
they are just cast replacments from precision, i just like cleaning every thing up, as rough edges are more prone to breakage than smooth ones, just have to careful not to take too much weight off a single piston compared to the rest.
yeah, its somthing to consider, but changinf to a 26 head would be a $5k + exersize, by the time i buy a head, turbo's, dump pipes, new injectors etc etc.
So im happy to stick with the 25 head and pay a few bucks to have the water gallery welded up and delete VCT
you know that a 26 head is an easier fit. no block mods needed
Actually, the 26 head needs the head studs tapped out bigger in the block.
The 25 requires a touch of weld and hey presto, bobs your uncle.
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
