Stag Series 2 - Air Con Filter Removal
Stagea_Neo
 Share
Hi All,
A while back people were chatting about removing the air filters in their stags, some cut plastic/metal to get
to complete the job, which is un-necessary. So here's my little guide to make things easy.
1. Remove the glove box retaining screws.
2.Remove the clip that holds the glove box tension cable.
3.Remove the plastic & metal backing/support panels.
4.Remove the various screws and loom clips.
Also those screws which keep the two halves of the air box together as it will
make for easier removal of the filters and to get a vacuum nozzle in there.
5. You should now have easy access to the filters.
Slide the top one out first, then lift the bottom one up and slide out.
There should be just enough clearance over the remaining support plate.
6. Inspect the air box for dirt, leaves etc.....
7.Clean out the air box, hopefully you have some small attachments/hoses to use here.
8.Bemuse yourself at how the aircon ever sucked/blew given how dirty the filters are.
9.Vacuum the filters as best you can, I found the brush attachment to come in handy here.
10.Give the filters a good soak/wash.... be careful with the charcoal pad on the reverse side
as it can be brittle or easy to rip off.
11.Allow to to dry for a couple of hours, or low heat in front of a fan heater for quicker turnaround.
( no pic needed ere :) )
12.Nice clean filters are ready to go back in.
13.Installation is a reverse of the above.
Pic of part number for reference.
quick question, what about blowing the filters with an air compressor (obviously after you get most of the bigger stuff off)?
i have an absolutely piss weak vacuum cleaner is all :devil: this is how i clean the filter on the vacuum cleaner as well :D
Edited by pyro-ns
  • 11 months later...
pretty sure that when i did this i just removed both the plastic backing plate and the metal one and then both filters were on display and that is all i had to remove, no loosening of anything else
I just took my filters out to clean them & all I had to remove were the plastic & metal backing plates behind the glove box too.
Good guide though. My filters were not as dirty as I imagined them to be.
i think they are the same as in the maximas, i heard somewhere that they are not much (either $30 each or $30 all up, can't remember tho)
also read somewhere that they have carbon in them to remove odor, so its probably not so good to wash them and blow them out
i've done mine and they are still going well, might be worth getting new ones tho
 Share
    • Embrace the freedom of casual encounters on the best dating app in town! Verified Maidens Superlative Сasual Dating
    • Slimline sub on the rear parcel shelf is doable. Pioneer TS-WX140DA is only 70mm high.
    • People like Johnny Dose Bro might be laughing at my post because I accidentally added 100mm to my numbers. 350-355 is indeed the lower limit. 450 is off-road Skyline spec.
    • What is the "compromise" that you think will happen? Are you thinking that something will get damaged? The only things you have to be concerned about with spherical jointed suspension arms are; Arguments with the constabulary wrt their legality (they are likely to be illegal for road use without an engineering certificatation, and that may not be possible to obtain). A lot more NVH transmitted through to the passengers (which is hardly a concern for those with a preference for good handling, anyway). Greatly increased inspection and maintenance requirements (see above points, both).   It is extremely necessary to ask what car you are talking about. Your discussion on strut tops, for example, would be completely wrong for an R chassis, but be correct for an S chassis. R32s have specific problems that R33/4 do not have. Etc. I have hardened rubber bushes on upper rear control arms and traction rods. Adjustable length so as to be able to set both camber and bump steer. You cannot contemplate doing just the control arms and not the traction arms. And whatever bushing you have in one you should have in the other so that they have similar characteristics. Otherwise you can get increased oddness of behaviour as one bushing flexes and the other doesn't, changing the alignment between them. I have stock lower rear arms with urethane bushes. I may make changes here, these are are driven by the R32's geometry problems, so I won't discuss them here unless it proves necessary. I have spherical joints in the front caster rods. I have experienced absolutely no negatives and only positives from doing so. They are massively better than any other option. I have sphericals in the FUCAs, but this is driven largely by the (again) R32 specific problems with the motion of those arms. I just have to deal with the increased maintenance required. Given how much better the front end behaves with the sphericals in there.....I'd probably be tempted to go away from my preference (which is not to have sphericals on a road car, for 2 of the 3 reasons in the bulleted list above), just to gain those improvements. And so my preference for not using sphericals (in general) on a road car should be obvious. I use them judiciously, though, as required to solve particular problems.
    • Easiest way to know is to break out the multimeter and measure it when cold, then measure all the resistances again once it gets hot enough to misfire. Both the original ignitor and the J Replace version. Factory service manual will have the spec for the terminal measurements.
