Oh, I could design quite a good plenum. That's essentially what I do in my normal work. But I wouldn't trust it on an engine until I had done some reasonably extensive flow modelling (probably physical, using my wet modelling methods, or also dry with air and some very accurate and small pitot tubes, and maybe with some CFD), because I know how hard it is to make a compact plenum do a good job of making the flow even to all the outlets.
It's even worse with IC engine plenums. Because the flow is not steady state from the inlet to all the outlets all the time, they don't flow the same as steady state plenums. Half the idea of a plenum for an engine is that the volume of the plenum is shared amongst all the runners on a more than even basis, because it's not supporting evenly divided flow to all of them at the same instant. So whilst that is true, it's also not completely true, because the air has momentum and inertia and will keep flowing towards an outlet even when the inlet valve at the other end of the runner has closed. And then you get the pressure reflections and all that jazz which get in the way too. So the flow situation is some halfway position between the two extremes which means you really can't design from first principles without serious testing, with the final type of testing being on a real engine where you can monitor the effects on exhaust temperatures and so on.
I helped a guy design a plenum with internal ramtubes for a VG33DET a few years ago. It worked fairly well, but probably only because of the thought put into preparing the air flow as it entered the plenum after the throttlebody. Because VGs commonly (and this one in particular) have the air inlet at the rear and therefore it has to turn through a large angle to enter the plenum, getting even flow into the plenum required the use of turning vanes welded inside the bend. I don't have pictures of that plenum lying around, but oddly enough, I do have pictures of turning vanes in a plenum inlet elbow for an industrial application on a minerals kiln. You can see them in the back view and the cutaway of the elbow. This plenum is designed to overcome some big flow problems inside the kiln without actually aiming for even distribution to all the outlets. Looks like a bloody nightmare doesn't it? I hope it works properly - hasn't been added to the kiln yet.
  • Replies 45
Posted Images
Very informative thanks.
Im not after more power, i am happy with the current power but absolutely hate the look of the engine bay in the race car with the crossover pipe etc. was a budget cooler and piping setup built from leftovers, so i was after something nicer such as a ffp, considering Plazmaman which i know for a fact work great and make up to 20kw extra with no lack of response, but pricey for this car. Still is an option just looking for a cheaper alternative.
With the freddy does anybody have a graph that overlays the difference to stock plenum?
Has anyone ever tried one of these cheap chinese (or thai?!) items for an R34?
http://www.ebay.com.au/itm/R34-skyline-RB25DET-GTT-NEO-RB25-DET-intake-manifold-90-/170501510358?pt=AU_Car_Parts_Accessories&hash=item27b2ae94d6&_uhb=1#ht_4521wt_974
I've been tempted to give one a go but its only going to delay me finishing my build even more, and I would need to change intercooler and a few other bits :/
Jex mate here is an extract from a convo i had with Fattony when i was thinking about the greddy install...
"330rwhp with Greddy
345rwhp with stock
Difference was the shape of the graphs. Greddy Straight linear line, like a highly strung N/A. Stock was a huge hump, massive mid-range flat-line at peak power from 5750rpm to 6750rpm.
I can't blame the Greddy plenum outright, but I do belive the shorter runners played a part.
Turbo is a 2835 ProS, I think boost came on the same with both plenums.
3rd gear, 21psi, 3500rpm.
2nd gear, 21psi, 4000rpm.
Felt much slower. Its all in the midrange. The extra power 4000rpm -> 6000rpm was the difference. Pedal response ON/OFF/ON throttle is probably better with the Greddy due to the shorter piping. It took some"
was enough to convince me anyway...maybe you could better tune your way around it i dunno...I asked Trent about it and he seemed very, meh whatever about it..:unsure:
How much did that cost you? And do they do one to specifically suit an R34 GTT?
I like the look of their design which is why I like the ebay one I posted up above.
The R.I.P.S front facing plenums have ram tubes inside them and they are known for their engine builds and power results... I was able to find one for my rb25...
Edited by JustinP
http://www.ebay.com....1#ht_4521wt_974
Work well just need the mounting flanges checked for warps, one or two came through in the early days warped.
+1 for the plasmaman if you can justify the cost and lack of room in the engine bay....can provide some pics if you want
What engine do you have sorry if been said before, if you have a look at Roys build thread he tried a couple of plenums and I think he went backwards with the plaz on his rb20. Fair bit of helpful information in there for anyone looking at rb20 setups as hes had numerous different types
http://www.ebay.com....7#ht_942wt_1163
i was wondering how long it would take for these to pop up for rb25's
no where near the cheapness of the rb20 plazman ripoffs tho
Edited by pipster11
Another option is the MX Performance bolt on plenum top. Cheaper than Plazmaman, and in my opinion it looks better too. I've just installed this to my engine, after swapping out from a Thaliand JUN copy.
your 740s maxed out..really ?..dunno where my 750s are at...how do we work that shit out I thought they would be ample for the task..
Cant wait to see how it goes cause I so nearly went there....still might if it proves worthwhile its a metre of piping I can lose...
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
