Don't understand why people won't spend an extra $500-$700 on a better pump rather than play oil pump roulette... I will build mine to last the hard time I want to give it not baby it because I am too much of a tight ass.
ive smashed an n1 pump - now using nitto!
n1 is like that movie fatal attraction
No pump is safe from being destroyed if you limiter bash. Even Tomei's can be killed.
spending more is not necessarily 100% fail proof due to the pump design!
Did not say it was 100% fail proof, but given the choice I do not see why anyone would go with an N1 considering their record. I would spend more (on a Nitto, Tomei, etc) to know that is was a 100% improvement over an N1.
And if you want to (or be safe from accidental) limiter bashing then go an external for slightly more coin.
fuel cut explains the massive flames that gtr's shoot out on the limiter - most gtr's u will see in japan run this way. so my guess is that fuel cut is acceptable but not sure if its better or worse than ignition cut?
  • Nope 1
errr....might want to re-read what you just wrote Marko.
No fuel = no flames
  • Like 1
Its been mentioned before so many times. But the clearance on the drive and pump is a problem in my opinion.
If you take a N1 pump gear and slide it over a R34 crank ir jun collar, there is .006" clearance each side. .012 total! It rattles like crazy when limiter is being hit. As mentioned just above. when limiter is reached the crank has to slow down before fuel is added to complete the combustion cycle. A loose crank/collar to pump is just smashing in there when its on the limiter. Every N1 pump or most pumps that have failed, crack right at the flat corner and then the rest is history.
Now i know im not the only person that figured this out. I have made new collars with .001" clearance each flat for a total of .002". Slips right on no problem but it doesnt have that loose fit like all the nissan cranks and Jun collars out there. i've gone through about 20 of them now with N1 pumps selling them to friends and stuff and not one problem yet.
Just look at this picture. Every crank you pull out looks like this. Its just retarded! the drive only has 3/16" contact. Crazy!
Ive seen almost every brand of pump brake. Looked at all the pictures people post up after and I always see the crank look like that.
Collar I made up. Just gotta flont the piece, lol. Im not saying there isn't a design flaw, but there is this one issue that is easily taken care of.
Would spark cut be easier on an oil pump than fuel cut?
same shit for an oil pump, engine is still stopping and starting in the same way. the only difference would be between different ecu's, for example, a stocker rb30e ecu cuts fuel to all cylinders when you hit 6200 and then cuts back in at around ~5800. a power fc randomly cuts cylinders to hold the motor at the set rev limit.
  • Like 1
No doubt it's a shit design...
Good on you for trying to overcome the issue!
My beef has always been the fact that there is only 2 surfaces driving the pump, why not have more so there is less stress on the surfaces?!?
It's a real pity the guy who was trying to make the splined gears got ripped off by his machinist :/
That may be my next step. Your totally right on tho!
What happened to the guy that was designing the splined gears? Machine work in Canada is relatively cheap. I got a few guys I use and its very reasonable. I'd like to see what this other guy ended up with as a design. Did he make new gears completely or just the inner gear and drive for the crank?
I think there has to be a cheap solution for everyone. Or we could all go dry and call it a day. none of this inbetween stuff ($1500 for same design pump)
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
