I have just fitted R34 V Spec Brembo calipers front and rear to my R32 GTR. The front calipers fitted with the V Spec 324mm rotors I have, but with the rear calipers, the rotor used (V Spec 300mm) are too small ie the brake pads are only half on the rotor. There is space in the caliper for a much larger diameter rotor. On searching the web I have found many comments that the Aug 2000 onwards R34 V spec used bigger rotors. Only on one entry though did they state the size - 322mm.
Can anyone confirm the 322mm rotor as a fact, and where I can get some from. The DBA catalogue only lists a maximum 300mm rear rotor for the Brembos.
thanks Mike
thanks Mike
322mm rotor is a fact. Sorry don't know where you could find some other than Japan.
Thanks. Yes I have now ascertained the following for anyone else who is interested:
- The R34 Aug 2000 onwards GTR V Spec & Nur models, rear Brembo caliper and rotor is 322mm in size
- The OE 322mm rear rotor from Nissan is $1100 each!
- Brembo 322mm rotors are available for $400 the pair
- DBA do a 322mm rear rotor for the 350Z (DBA 4601) which is almost identical to the specs of the Skyline 322mm rotor, only difference being 0.5mm difference in original height - Skyline (63mm ht) and 350Z (62.5mm ht) $510 the pair
  • 1 year later...
where can i buy the brembo 322mm rotors from $400 seems a bargain - i need to replace mine
GSL RallySport - 1300 884 836, or PM me.
Brembo Std $238 for the pair
RDA Std $238 for the pair
RDA Slotted $309 for the pair
DBA 4000 Series Std $330 for the pair
DBA 4000 Series Slotted $490 for the pair
Project Mu CRD Slotted $519 for the pair
Project Mu SCR Slotted $875 for the pair
Brembo are in stock, RDA and DBA should be in stock, Project Mu you might need to allow a few weeks to order in.
Regards,
Greg
Correct! To the point where most manufacturers just round it up to 63mm in both cases:
As discussed -
According to Project Mu there is clearly 1.5mm difference between hat sizes on the z33 rear and the r34 gtr 322mm rear rotors.
Like i said to you im not interested in buying something that will work, I want the one that was designed for my car and will centre correctly in the caliper
Project mu website
Thanks
Jason
I just bought mine through the local brake place (Southwest Brakes Bunbury WA) in this case. They were in Brembo boxes.
Have worked fine
regards
Mike
As discussed -
Thanks
Jason
Project mu have a proper rotor in your size. Hatted, slotted, everything. Get those. For some unaccountable reason they dont make them in the right size for rears on the rest of the GTR range.
Descrizione
The PROJECT MU SCR-PRO Rotors - Rear Nissan Skyline GT-R BNR34 are designed specifically for high horsepower output vehicles. SCR-PRO rotors are constructed as a two-piece rotor design. SCR-PRO rotors are developed from super tough FC Cast Iron Material and are heat-treated for reliability, durability and thermal stability under aggressive driving. The affixed bell housing is made from a billet aluminum alloy for strength as well as reduction of unsprung weight. Project Mu SCR-PRO rotors are available as front and rear replacements including vehicles with the factory Brembo calipers. They are manufactured from the factory featuring a slotted and dimpled surface to facilitate better pad wear and maximize cooling and braking performance. SCR-PRO rotors also feature a specially designed internal vane to improve heat dissipation from the rotors.
Product Specs
Brand: PROJECT MU
Product: SCR-PRO Rotors - Rear Nissan Skyline GT-R BNR34
Part Num: GPRN012
FEATURES:
- Compatible for Vehicle inspection
- Special Heat Treatment
- Compatible with Circuit Use
- 8 Straight Slits
- Black Painting
- 2 Piece Structure
SPECIFICATIONS:
Application: Rear Brakes
Structure: 2 Pieces
Slits: Straight/Eight slits per side; sixteen on both sides
Materials:
- Disc: High-alloy high-carbon FC cast iron
- Bell Housing: Aluminum alloy
Dimensions (mm):
- O-D: 322
- Thickness: 22
- P.C.D.: 114.3
- Holes: 5
- Height: +2.2
- C.Bore: 68
PRODUCT NOTES:
- Project Mu Bell Housing are 2.0mm wider compare to Stock OEM. When mounted the wheels will have a 2.0mm offset.
COMPATIBILITY NOTES:
- BNR34 N1: Only vehicles before 8/00
- BNR34 Standard: Only vehicles after 8/00
Compatibility Info
Nissan Skyline GT-R BNR34 (Zenki - 1/99-8/00) Eng: RB26DETT
Nissan Skyline GT-R BNR34 (Chuki - 8/00-10/00) Eng: RB26DETT
Nissan Skyline GT-R BNR34 (Kouki - 10/00-8/02) Eng: RB26DETT
Having said all that I am not sure how they cope with wear from the handbrake. Some other types have a steel liner on the hat for that very reason.
Edited by djr81
The mounting face on the Project Mu Skyline rear rotors (both 300mm and 322mm) is 1mm thicker than it is on the Project Mu 350Z rear rotors, and so to compensate for this, the Project Mu rear rotors are made to 64mm to centralise. If you don't beleive me, have a look at SCRN008 (300mm rear), which is also 64mm according to Project Mu, but is 63mm according to both RDA and DBA, and indeed most other manufacturers. The manufacturers overall height will vary a mm or two in some cases due to their preferred thickness of the mounting face part of the rotor, in order to keep it in the middle of the caliper. The actual, real world, bolt-it-to-the-car-and-measure-the-difference-at-the-caliper is only 0.5mm...
They do, they make CRD and SCR to suit 300mm rear, but only 322mm rear gets the two piece SCR Pro.
Actually the 2mm thicker alloy hat on the front caught me out. I put them on then wondered where all my thread depth on the wheel studs went.
Yeah I have the SCR's on the rear of my car. They weigh a tonne & have more vanes the the SCR Pro's. NFI why they would do that. But they haven't cracked.
yeah I wish they made the SCR pro 2 piece in regular GTR brembo size for the rear as well. they are good rotors. other option is a biot kit which comes with bigger rotor, and new caliper mount bracket to space the caliper. they are a nice 3 piece rear rotor (rotor, hat, and inner bell for the handbrake). a bit on the $$$ side though.
  • 8 years later...
300mm solid rotor for non V-spec from my experience.
If you need help with DBA parts I can help source them for a good price, the part is DBA4929 or DBA4929S for slotted or DBA4929XS for Slotted & Drilled.
According to my list (which I have copied from a website and cannot verify as being 100%)
The R32 GTR had 296mm rotors with Sumitomo calipers
The R32 GTR V Spec had 324mm with Brembos
but the  R33 and R34 GTRs had 324mm with Brembos on both base and V spec models.
You're referencing front rotors :)
@adey was after the rears which comes in 3x different diameters
Oops you are right - my list doesn't mention rears ?
Thanks guys!
FWIW I've found 2 references on yahoo japan auctions of rear BNR34 discs -- not specified as V-spec discs -- that were 322mm in diameter.  That doesn't mean that the sellers didn't "forget" to include the word vspec, but it's 2 data points.
But, I'm pretty sure both the 300 and 322 rears were both vented rears...  the R32's 296s were probably vented, too...
So, the search continues...
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
