  • Replies 181
ok guys if you are reading this please give your opinion im looking in to all the part for the gtr's suspension
im stuck in what to get.
i dont have the buget to run with the Ikeya Formula stuff so what should i do????
do i go with the JUST JAP stuff or with say CUSCO stuff like everything?????
please i need help
I'll pm you the good info and am with Bris! To much money gets wasted in wanky susp for club cars.
Just copy my car. Has nothing to fancy and does pretty well for what it is. Cusco fixed upper arms 3.5deg, adj Cusco rear uppers, tien castor rods and whiteline swaybars with bilstiens. Get the fronts for about $250 secondhand, rears prob $200. Swaybars $500 new. Castor rods $150ish. It has never put me in a bad situation. You having never driven a gtr hard it going to take at least prob 10 trackdays before you even begin to understand how to steer the car let alone touch the susp.
Better than putting $5000 susp in your car you can't understand. The extra trackdays you could do with the money you saved would be more benifitial. I don't get how so many guys do one track day with maybe 25 laps in groups of 3 laps where ther car only does 2 fast and then say they need to take the car to the workshop because it doesn't handle right. They prob haven't even learnt how to drive the new setup! Don't get caught in the cheque book racing.
I was talking to your Dad at the Aust Supersprint Champs about this, it sounded good when he said rotisserie!
I have the following suspension on my R32 and it will run 47's at the Island no problem....
Front:
Nolec Adjustable upper control arms - unfortunately I don't think these are made any more, but worth a look
Cusco castor rods
Whiteline 24mm Front bar
Tien RE shocks that have been revalved
650 lb springs
Rear:
Tune Agent Upper control arms and traction rods - mostly for easy adjustment and to replace the old factory stuff that is about 15 years old
http://www.tuneagent.com.au/public/merchan...gory.aspx?id=84
Whiteline 22mm rear bar
~450 lb springs I think
The HICAS is still in place
Nothing too over the top and have found all parts bullet proof after 5 years on the track and about 10,000 road k's.
Regards
Andrew
i wish my old man liked my car just a little... its always jap crap get a real car like a commodore. then we pull up at a set of lights and i spank the bommodores ass harder than my house maid
well time to update,
Christmas has passed and now time to get back on track!!!!!!!!!!!!!!!!!
with dad clipping me tell me to get back in to it this is what we have done this weekend.
photo of stuff going to be blasted
the rear sub frame out and painted
gear box mount to be washed and cleaned before painting
stuff being painted
more of the stuff painted
and now that looks much better
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
