I have searched these forums for info on how to make an R33 GTR into RWD, and found little helpful advise based on R33's. I'd like for someone who has done this before, by removing fuse or front shaft (from transfer case to front diff) to comment on how this was done / any problems encountered?
Also Mine is a V-Spec, so dunno if this makes things more difficult.
I understand pulling the fuse isn't the answer (on R33), but what does this do exactly?
https://www.sau.com.au/forums/topic/29019-how-to-r33-gtr-rwd/
All you need to do is pull the fuse in the boot and bleed the 4wd pump of fluid, no need to drop front drive shafts.. I've had mine done to dyno it and causes no probs at all. Just make sure they do the screw up properly when they've finished otherwise you leak fluid... You lose around 60ml of transmission fluid that's all...
Mines a Vspec too...
Cheers
Brett
I may be wrong here, but I'm sure HKS or one of the name brand makes a "rod thingy". check out www.greenline.jp I think I saw one there.
I also remember checking out a GTR Vspec that had heeps of these gadgets/switches, one to switch the HICAS on/off, RWD/4WD on/off, Rod to reduce the sound of the exhaust, an on/off for the ATTESSA...etc
He's a SAU member, can't find the link but user name was En_One his contact numbers are 0415210220 or 0421531468 or email to [email protected]
Maybe give him a try, seemed to have every gadget under the Al Quaida Sun.
meshmesh are you referring to the HKS Drag Controller?
Buggered if I know??? All I can remember is that the car had 3 flick switches where the ashtray goes, & a rod about the size of a pushbike tyre pump, that was on the passenger side of the centre console. Also, I about 100% sure, he said one of them makes the car RWD only, which he used for track work. Is that a drag controller?
On a non-V-spec you just pull two fuses, one in the boot and one in the cabin and bingo, RWD central. I only drove for a short time and the clutch was slipping anyway so can't really say what it is like to drive as a RWD.
But that really doesn't help the original poster. But might save someone with a non-V-spec doing something silly like pulling their car to bits...
My understanding is that the remove the fuse option is not safe with R33s and later, apparently there is some wear on the clutch packs that does not occur with R32s.
And without meaning to hijack, when the forums were lost a thread re the HKS torque split controller was lost. Does anyone have any experience with it?
Thanks for the opinions guys.
CerealKiller / Blitz - I want RWD for drift and skidpan days. 4WD sticks too well and therefore limits my fun. harhar (evil laugh)
EVL R33 (Brett) - Have you removed this fluid yourself before? Could you perhaps elaborate on how this is done? Where is the 4WD pump found?
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
