  • Replies 160
Best way to do it I find is to unbolt the washer bottle, go for a drive running over the thing and dragging it and anything else out anything else it touches including the wiring for the censor going onto the hub.....job done....it's now 2WD with no ABS. :)
seriously though....disconnect the pug connecting to the sensor....me thinks....unless my box was stuffed before then. :P
Dear Mr. Jetwreck,
Could you post a link to the website where I can find info and pricing details for this intercooler.
Thanks in advance for you kind assistance.
Regards,
Roullos
This is there site on the forum.
http://www.skylinesaustralia.com/forums/Hd...hdi+intercooler
They are on holidays till the 4th January.
I believe price of the total kit including new thermo fan and new piping is $899.
If you just wan the cooler and going to use your own piping and fan it is about $450.
Cheers
Andy
Or HDi ECU lol
ill keep u guys updated on this too
sounds very promising
like having it's own map sensors instead of getting it off the AFM :D
Hey mate,
How much did that FMIC set you back?
do you have any idea how much it would cost to get it installed as well?
cheers
Woops... should probably read the whole thread.. my bad!
Edited by macdog
  • 2 months later...
HDI are now starting to get there kits for the M35 in stock and i was lucky to get the second production kit and the next shipment is due soon.
So what is it like.
The kit supplied is very comprehensive and has everything needed to do the install included in the kit. I opted to supply my own fan as replacement for the factory fan that has to be removed to create more clearance for the FMIC.
The removal of the front end of the car is relatively simple being, removal of grill (4 x press clips + 4 clips along the bottom edge of the grill). Removal of the front bar is almost as simple with 2 x press clips to remove, the screws along the bottom edge of the bar connecting the under tray and a screw in each wheel well.
Next thing to remove is the reo bar which is 4 bolts on either side.
Removal of the standard cooler is simple but make sure you keep the bolts as you will need them to put the new one on.
It is also recomended to remove the bolts holding the washer bottle in place but don't forget to bolt it back in.
Removal of factory AC fan.
The kit is quite straight forward to install.
Install your new slimline fan first. There is a little fiddling to get this in the right spot.
When you start on installing the piping start from the pipe running up to the throttle body and (drivers side) and fit it to the throttle body. Then connect this pipe to the intercooler and mount the cooler in place. The last pipe to do is the one from the turbo and is a tight fit and a bit of detergent will help here. There is a little more leeway on the passenger side with the pipes which is why I suggest doing it in this order.
Then put all the other bits together.
My car has some mods but are limited to;
* 3" exhaust with dump pipe from the turbo
* plenum spacer
* K&N filter
The result:
The car feels much less choked now and revs very smoothly through the whole rev range.
Boost is identical, 14psi bleeding back to 12psi at higher rpm.
The car comes onto boost more easily and feels like it is pulling better off boost. When it is on boost there may be slightly more power than with the standard cooler but it has more power down low in the rev range with the car wanting to step sideways now when pushed hard from a standing start around a corner. This never happened in the dry with the stock cooler.
The M35 is a car that seems to suffer quite badly with hot days with the motor retarding and fuel consumption increasing especially after a few hard runs. I installed my kit 2 weeks ago, just in time for the end of summer heatwave of about 35C where I live even in the evening. The car on these days just kept hauling with no flat feel to the motor and the car just kept pulling hard when I asked.
The fuel economy seems to have improved with the average economy being about 0.2L/100km better on suburban driving.
Overall I am very happy with the upgrade, easy to install and the improvement to the overall driving of the car has been great. I think the full benifit of this cooler would be felt more on a highflowed turbo but on the stock turbo it has made a good car even better.
Cheers
Andy
i cant find the FMIC on the fiat. anyone know where it is??
im not sure if im going HDi yet or jap branded
lol on the Fiat....I new you were sandbagging the power of that thing!
Tell me....I gotta know.....Why would a Japanese brand be better? Excluding ARC.....I am talking around the $1,000K mark delivered.
Enlighten us Iain...... Wouldn't you buy the best performing intercooler that fits the car and your budget.
I know the Blitz one is now available in Oz but it has worse flow rates, what would be the benifit?
:thumbsup:
I am yet to puchace my upgraded cooler Cam, smart arse. :)
I will find a sucker to take mine off me when the time comes, but until then my $99 dollar special will have to do, at least its better than stock.
i just like japanese kits. its made FOR the car, and not a kit modified to suit a car.
Are you saying Blitz and alike make the core solely for the M35?
I thought they were using there standard size coolers just adapting the piping as required. (same thing HDI did)
I know ARC have one that has a core made for the M35 but that is the only one I have seen like that.
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
