have a look in the DIY section for the tutorial on changing fuel pumps. they are generally for the r32 or r33 but they will give you a pretty good idea of what you will be looking at in the r34 as well.
  • 9 years later...
On 10/11/2009 at 11:04 PM, 666DAN said:
The only thing that doesn't match up is that the N/A doesn't have the relay for switching the pump to a higher feed voltage (when on boost)
Epic thread bump, Anyone know the ins and outs of the above comment? If it doesn't have the relay to adjust pump voltage does this mean the static pump pressure is higher or lower? I'm guessing lower but if so what voltage is that? Thanks!
  • 6 months later...
