heaps of cars out today...
spotted a white 33 with kit and rims near centennial park....
gunmetal r32 near randwick race course... another white r33 near fox.......
heaps of wrxs and 200s out for the tigers game too...
someone spot me dammit!
Ed
Wilch
"Saw a 32 GTR on the Cumberland highway too. It had a cf bonnet, and gold dished rims. "
that would most likely be UREADY as i spotted him on
milperra rd/Newbridge rd...i was in my work car with my mates..chatted to him to say congrats on his 10sec pass ;)
spotted ranicx on bondi road thisafternoon stuck in traffic ;)
spotted another sleeper R33.... pretty stock but went well and blew a hell of black smoke on me when gunning it..... this one was ED and anzac :)
Anyone seen me yet??
i spotted a white cefiro on victoria avenue chatswood out the front of car wash cafe. I actually saw you twice. For once i was in the GTR instead of the soarer :D
was it you CC?
was it you CC?
I drove past that one also, nice looking Ceffie I must say.
Spotted lots of Skylines up in Sydney yesterday, ost noteable being a silver R32 GTR with silver dished wheels and a CF bonnet and a white R33 GTSt with a big Nismo sticker across the windscreen and 400R kit.
I have no idea what road I was on though as I was extremely lost :D Was heading from Blacktown/Windsor area towards the M5 to get back to Canberra. Would have been around 1PM.
EDIT: Forgot to mention the guy in a stock-as-a-rock E36 318i proudly displaying a very crooked M3 badge on the rear as well...
Edited by Amaru
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
