yeh thats them they called that gtir rwd-r
also did a full mines response r34 gtr awsome car that was
Yeah, that's Sasha (Japboyz). You'll find his workshop no longer exists, as he got out of the game. Between him and Chris (the MINES R34 owner, and the guy that imports most of Autostyles cars), they have some damn nice stuff... :( The Escorts are sold as well...
I regret to say that dog is no longer - got run over by a car ;):D
SPotted a white 32 t. on walgrove road today.. I thinka chick was driving it.. it was really clean! :( Any ideas?
I think that was BWA :P
Lucky girl! You've only had the car for 3 days and you've been spotted already. It took me months before I got spotted.
Spotted 2x Gunmetal Grey R32's in Hornsby.
(Missed plates)
Saw a grey R33 GTST Type II also in Hornsby.. Plates were WQF-3??
hmm...I have an R33 GTST but series 1 with series 2 wing....not my plates though but im always around Hornsby in it!
where and what time?
Spotted Dragon yesteday morning again
<_<
ugly spinners and a kermit green paint job
Yer i spotted him at UAS a few weeks ago... Not a real fan of the spinners :P
spotted LIZ (Miss Turbo), jeff (jeff33r) and john (flukey) at homebush just then, LOL nice meet up guys... hehe shame it wasnt earlier could of went for a nice cruise...
Edited by mass_iv
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
