Were you in a undercover car or something? Didn't notice any other skylines this morning.... Sif I was hooning :)
lol..
nah I was in skyline, I was heading towards city you were passing Epping Hotel heading towards pennant hills.. I even waved, but you were not looking my direction
Spotted a white R33 on Kissing Point Road heading towards Silverwater Rd at around 6.30 pm.
Also spotted a silver R34 GTt in Macquarie St, Parramatta at around 10.30 tonight.
Spotted 3pm a White R33 with green P Plates and a 400R rear bar on Lane Cove Rd, looked tidy.
Also a Silver R34 with a few decals, stickers, including writing on the front windscreen, in St Ives, near the flower power place, car looked damn nice :huh:
I was stealthed you wouldn't have seen me.
Spotted a white s1 R33 today in Seven Hills, with no rear wing and primered/matt black bootlid.
It pulled out of one of the factory complexes near where the new NRMA service centre workshop is, then went up towards Blacktown via Wall Park Avenue and onto Main Street past Blacktown hospital.
spotted a maroon r33 on abercombie st , a dark blue r33 on paramatta road going twds the city and a white r32 as well on para road... all on monday
and none of the aforementioned bitches spotted me.. or were not on sau >_<
Spotted a Stretch Hummer on Victoia rd this morning gunmetal colour plates HOLYWD looked awesome
I'm getting driven around in that hummer on Saturday night! Glad I'm not paying for it though!! :eek:
Spotted Primordial driving past me on Castle Hill Road last night.
Never get sick of seeing those LED tail-lights :happy:
A-ha! i spotted you and a flash of the red number plate so thought it must have been you! :D
Also... I think I spotted Lime Cordial walking through Westifield Tuggerah on Sunday... was extremely hungover and could of been hallucinating though!
Hahaha.. you're spot on. :nyaanyaa:
I dropped in there on my way back from Port Stephens. I was EXTREMELY hung over as well.. I only had about 3 hours sleep since Friday morning by that point of the weekend :D:ninja:
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
