Hahaha are you sure about that ?
I was minding a bayside blue R34 GTR for the weekend and I left my car at my parents house so ummmm unless you meant the previous sunday it probably wasnt me!!!
I'm fairly damm sure it was you.
i saw him at broadway yesterday around 5pm...
nah wasn't at broadway :P
and saw a black 34 gtr with a 3 letter number plate near the casino today.. sounded nice...
what sounded even better though was a sexy ferrari that hammered it past me on the bridge this morning... never really heard one being hammered on the roads and it sounded like sex! :drool:
spotted a yellow R33 gtst on military rd NOrth Sydney around 1ish today, with a vented carbon fibre bonnet, black roof and black boot, white rims
yay i got spotted :sorcerer:
that would be me on my way back from northern beaches performance
You shoulda raced it!
Spotted - Last night, around 8:30 - 8:20 White 32 something, plates DAVINO or GAVINO (damn this lack o' memory) at the Artarmon station, shop side...
Saw like 6 skylines yesterday, but every time i see a new one, it pushes the last one out of my memory :closedeyes:
Special mention to the grey one i saw in pymble around 3:30 i think. I was on pacific Hwy, He was turning on to it, gave a toot of the horn, got a little wave... It was something special :P
Saw a silver 33 at the entrance to the M2 at Seven Hills at 3:40 am last night...
I couldn't help but think... Trust the only other car in sight to be a 33 :P
gave him a flash, but I'm sure i just pissed him off :unsure:
nah.. he was going the other way and passed right next to me!!! :drool:
spotted today, a silver 33 with a SAU sticker on the rear window... he parked in front of me in a carpark off harris st :blink: I was there visiting one of our sites :)
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
