OMG NO WAI! I saw it and thought that reminds me of mass, but the wheels were all wrong! forgot vpsec changed them!! btw, the new rims look hot :O i was admiring! and if i'd know -MASS-' front bar was attached i'd have given chase... cop or no cop :D
LOLzors!
i wouldn't have known what to do, get defected or lose a front bar
Im good thanks and u?
:D
arent i welcome anymore?
omg, noob gtfo
OMG NO WAI! I saw it and thought that reminds me of mass, but the wheels were all wrong! forgot vpsec changed them!! btw, the new rims look hot :) i was admiring! and if i'd know -MASS-' front bar was attached i'd have given chase... cop or no cop :O
hahaha yeh u always loved that front bar hehehe..
watch out greg
If said R34 had an obscenely huge wing on the back that could have been me...
Visiting various panel beaters and collecting quotes to remove the monstrosity of a wing
Also, spotted a series 2 R33 parked next to me at TAFE tonight
and a couple of people taking pics on their phone :D
Hi if you're on here
yeap :)
was "kinda" speeding...
but definately de-wing
:O
Haha if it was around 630-7 ish that was me :thumbsup: , no way in hell i was going past him
I think I might have seen you filling up at BP thornleigh on Tuesday night at about 7:30. Was that you?
I think so, with SAM916, msnismo and Qantas. Does your car have white impuls/starcorps? If so i saw you too
LOLzors!
better to be defected :P
:D
watch out greg
awww.. HI -MASS-!!! you know we all miss you!!! especially me! well.. i may just miss the gelato.. but you know how it is :no: *hug*
better to be defected :)
awww.. HI -MASS-!!! you know we all miss you!!! especially me! well.. i may just miss the gelato.. but you know how it is :P *hug*
hahaha thansk -MONA- i feel really welcome... :(
i miss my old beast.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
