DEV 10S (black 32) in Hornsby just now, a Stagea at Pymble Prestige smash (in Hornsby) and a 34 also in hornsby driving past the station...
got a mean look from the 32, nothing from the stagea (being IN the shop, thats to be expected), and a wave from the 34... but i think he was thinking wtf for a while...
Doof, what colour was the Stagea please???
Pretty sure i spotted some of you fellas last night... and a lass :(
Though i don't think I properly introduced myself...
;) sowwy if i didn't... I'll give you a BIG scary hug next time i see you :)
Just saw a black 32 GTR with yellow plates... passanger was looking back, i flashed lights but dunno if you saw... passanger looked familiar too ;)
Adorra - adoraa however you spell it... Hi bish :)
Spotted Grey 33 4door (with space saver on the rear)today in Newcastle, driver pointed at our car (grey 32 4dr), and spotted also Silver R33 GTR heading towards charlestown.
I should post here more often as I own a skyline myself :P
spotted more skylines than I could count on both hands within a space of 15 minutes... r33's and r32's all around dural, castle hill and baulkham hills..
oh.. and one sexy midnight purple 2 R34 GTR VSPEC.. mmmm sexy car Mass :(
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
