Last 2 mornings I spotted a Midnight Purple II R34 GTR rego XX34XX in west ryde on vic rd near the shell yesterday and today at the intersection of Adelaide St and vic rd. Looks Hot as! wouldnt see me i was driving my red corolla yesterday and my dads commodore today.
Hey mate thats me... thanks...
yeh wudnt have noticed you.. iv been driving my car around lately hehehe i cant help it, its still new to me ;)
dont be shy to say hi next time.
Edited by mass_iv
exact words.....i dont want it to be a daily...AHahAHahAHahAHahAahAH yeah right ;):(:)
spotted a 34GTR bayside blue drivin down hurstville........i was in the bat poo infested supra covered in 3" of dirt lol
Edited by carmasupra
WPN - that was James, Lingeringsoul.
I also spotted a few guys today
Brad,Anna, smoky, doof, Kell, James from SAU NSW
and vrom SAU VIC - Mav, Scotsman, Bec, and a few others!!
Also spotted 321 GO R32 after leaving EC today :happy:
And spotted my car after to weeks
Cool i had a feeling it was someone from sau, dont suppose you or him saw the maccas semi trailer truck up against the power pole right at the entry gates to EC? looked like he ran off the road & clipped the pole with the trailer.
yesterday arvo coming past eastern creek i spotted that blue/white & red r32gtr(is or looks like the old race car)
edit: it was on a truck or trailer.
Edited by RSTME
RSTME - JasonGTR or GTRJason from here :whistling:
spotted a few SAU NSW members go karting today!
And while filling up at BP near airport, spotted a 32 GTR pull in behind us.
RSTME - JasonGTR or GTRJason from here :(
awesome,is it 1 of the old race cars from bathurst?
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
