spotted a Blue/Grey Two tone R33 Female Driver yesturday around 5:15PM turning onto Moorebank AVE near the bread makers thingy
Plate: MEL 24C
very tidy car.
PS if you are the owner of this car im not sure if you saw me, i was the guy in the black jacket and Blue tie walking around the corner, my line was parked around the next corner =P
Spotted a black R33 on the M2 this morning as I joined it from the Cumberland Highway. Looked clean and tidy. Thought I might've caught the driver taking a phone camera snap of my car - could've been for this thread? :woot:
EDIT: I think the rego was AZJ-93M.
Edited by HuH
f**k! Jeremy! I saw you pulled over aswell but it looked like you were on the phone!!!!! I didn't know you'd broken down!!!
so sorry! I would have stopped to help :rofl::(
That's okay Liz, thanks anyway.
As it turns out with the alternator belt going cause me to blow a welch plug behind the turbo. But it's all fixed now.
33 GT-R on Roberts Rd, South Strathfield. Running an aftermarket ECU, judging by the rear bar
loser of the day: atmo, auto, series 1 33 with a GT-R badge. give urself an upper-cut, mate :)
most homo numberplate of the day: OMG-16V, omg! it's an 18 year old twincam Corolla OMG BRO! SIIIK!!!
Im up at coffs harbor and spotted 1 white r33 with P plates gave the bloke a wave an he responded. There are no people up here with skylines?!
In qld driving the r34 people were falling over themselves checking it out.. Alot different to sydney and quite strange as I snapped a shot of a Audi R8 sitting outside my camp site one morning bloke just took off for a surf go figure. Did not even hear it rock up whisper quiet.. Shit sexi car.
Anyways yeah.
Spotted 3 tonight on my way home from work. 2 of them within 50 metres of each other right next to Hyde Park. The first was a dark coloured 32 that I beeped at to say hello. Looked like it might've been a girl driving? Don't think they realised it was me beeping.
Then just in front was an R34 GT in silver. This was at about 6:30ish in the evening.
Then on the M2 there was another gunmetal 32 with rims. Plates were BCN-32P I think? I followed them for a while until I had to get off onto Pennant Hills Rd.
was passed by YLD-34T on the northern distributor (wollongong) today.
Anyone here floating about in the wollongong area? I'm living down here for uni currently. Know a few R31 guys, but most of them (BJ, you poof) have left the area now.
I've got a Champagne 180SX
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
