spotted greyish, maybe gun metal gray r34 vspec 2 gtr, with the plates vspec2, on forest rd penshurst dominos, i was the half naked guy standing on side of the street with a dominos chick in a square suit made of pizza deals :D
oatley on friday saw a white r33 GTR parked outside coles then a black R32 gts
then saturday saw a white R33 gtst cruising next a white ferrarri which im pretty sure is owned by one of the queens st customs guys at their shop, the one down the road from bankstown airport (not sure of suburb)
Just spotted a white r33 gtr on Richmond rd/ Knox rd, looked nice except for those ugly bling bling tail lights..
U gassed it at the lights abit,, were u wanting a race? Abit silly since I had a 7yro in the car
Cruised with a black na R34 4door along Pennant Hills Rd and up the freeway all the way to the Gosford exit at about lunchtime today.
Edited by Jay.R34
Spotted Mr Doof in Chatswood area on Friday night on the way home from Twilight drift. Turning right onto pacfic highway. Was in my mates car so i just yelled at you haha.
Spotted a white V35 sedan parked on Hawksbury Road in Westmead today, behind Westmead Hospital.
Also, I've been spotting a non-turbo black R33 coupe parked in Girraween on Targo Road a few times lately.
That was MEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE..............................
i spotted you on the M2 made my way up to you, was great i had Eye Candy pretty much all the way home, Just moved up there :D
spotted a KV2 silver R34 coupe turning off Prospect Hwy onto Station Rd in Seven Hills
Also spotted a wingless gunmetal grey R32 burble past me turning off Prospect Hwy onto Lucas Rd in Seven Hills
if any of you guys are on here, heya, i was in the black R34
saw this in chinatown other day, opposite the capitol theatre and harrys hot dog stand..beautiful in nismo blue.
spotted the white one on bathhurst st last week i think. sorry, slow at getting phone near the laptop :P
spotted silver series 2 on james ruse drive at around 2ish i think it was
spotted a white 33 on the freeway heading south bound
had GTR kit on it * could of been a GTR *
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
