lmao serves him right
Hahahaha I agree. You can tell what sort of people they are when they start acting like fully sicks when they are in need of help.
I hope it wasn't insured either.
:cheers:
Spotted charcoal R32 GT-R on old windsor toongabbie few nights back, plates were NOCHNC but the way he sped past me and cut in front of me his plates shoulda read NOBRAINS
was fairly loud (was no ambient noise though so anything would have seemed loud) but did seem to have HID's so may very well have been :) looked the goods :)
Probablly mine mate! i have fairly whitish lights but hardly HID quality
Was heading down to Macquarie off memory.
Spotted a r32 gtr at the set of lights on pennant hills rd and north rocks rd about 10pm if your on here i was in the white 33 with primer spots all over it :-P
Hey man, think it was me coming back from gf's house castle hill way. dont remember seeing you, where bouts were you??
JD.
Spotted wat could of been dave (aggroman) on newline last night at hastings rd lights....red 34 sau sticker....i waved as i went passed dont know if you saw.
that was indeed me.. sorry i was too busy saying "motherf**ker where did he get them side skirts!"they didnt just look like sideskrit extensions but more proper GTR skirts.. Care to enlighten me? perhaps by PM?
spotted Matt in his Nur1 just before he turned onto the freeway to sydney on way back from Dinner of legends last night.
we were in Mr Stabby's black R32 and watched the gorgeous R34GTR just disappear down the hill..poetry in motion!
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
