Spotted a white 32gtr at space station (shell) on epping road at 4.20pm today. Car had a sau sticker on the qtr window :)
That was me DIF! Yew!!! No mention if the car looked any good dammit!
spotted rr33yo this moring in the tunnel off castlehill rd onto penno rd, sau sticker, car sounded nice going through the tunnel.
Yay spotted :) i lovvve that tunnel.. what were u in mate?
Well, you know what they say.. If you can't say anything nice don't say anything at all...
KIDDING..
Nah looked pretty clean and sounded alright.. You need to rub that silly "drag/race number" off the window.. I can't stand that on cars..
Haha I was right behind your mate at the counter I was going to go over and say hi after I paid (I was just in my daily) but you guys left.
ahh i was in stealth mode my friend...in my work ute with mower on the back :)
also spotted a black na 33 leaving maccas at dural last night....i gave a little flutter as i went past when u were turning off (if your on here)
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
