Chris I'm getting Nepean Smash Repairs out at Emu Plains to redo my front bar. Terry recommended him after I hand a ding in my rear quarter. He knows how to mix midnight purple perfectly.
104 Russell Street
Emu Plains NSW 2750
(02) 4735 3522
Might be a bit of a trek for you from Wollongong but I don't know of anywhere else in Wollongong where you could go.
Cheers,
I just ended up taking it up to Bodyform today.
It's a decent drive but with his rep I'm confident it will turn out good.
I was just too worried some one down here would butcher it
Spotted Jennie's white R34 at work this morning.
They look great next to each other! :-) Wont need to check my passanger door for dents today either. Haha have a great day!!
For that exact reason, it's great when you get to park next to someone you know :)
That's right! Some people aren't as careful as others with their car. I am always careful not only so I don't hit another car but also so I don't damage my own! With a GTR next to me I don't need to worry. :-)
Waved to a silver S2 R33 in Albion Park today.
Not sure if wave returned, was checking for SAU stickers.
Near croome rd? Caught me off guard but i gave a nod... Ch'ur bro style.
My cars been playing funny buggers lately but I had intentions on going on last pizza cruise but carputer said no. Whens the next one?
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
