Dude the 32 in st Clair is nice I hate the kit tho !
He drives it like a grandmas car but at the track he is pumping 300+kW at the wheel
really? it looks like ass haha the wheels and kit are a sin, impressive if it does really have that power but
Saw a black R34 GTT with black wheels at St Marys station just then I think the plates were BNQ-03Q. I was in my mums silver Camry right next to you
That was me! waiting to pick up the mrs. lol first time spotted :D
Woo! I've seen you before sometime last year on the Gt Western but that was before I got my Skyline. I remembered the black on black
Just saw Ricky(LL00LL) passing me while I was parked at Tangerine St, Fairfield East.
Flashed my high beam, saw your hazard light. You've got the High JUN stands now like me. Real niiice in all black!
Had a nice chat with Terry whilst admiring the GTR at the Charity Car show in Springwood. Was nce to meet you. Your car is stupidly nice.
You're very kind Liam. Hope you had a great day! I rolled up at about 11 thinking that all the tarmac spots would surely be taken. Our family only wished to stay for a couple of hours because Maria was on an extended test drive of a new car on the same day. Plus we bought it. So the Cameron Burke Show was only an afterthought. Great meeting with you!
  • Like 2
When will it be mine turn to own such a beautiful creation.
A little off-topic, but do you have any other pictures of this on these forums, or just in general?
I've only been privileged to see 2 or 3 photos of your car, and unfortunately they've all been of the same angle/point of view.
Thank you for your appreciation :)
I still go out to the garage at times to think how lucky I've been.
This N1 has been shown before in...
SAU > Photography > R34s
And if you require hi-res, email me on...
[email protected]
Regards
Spotted the same HR31 Coupe [YRB20T] but driving. Had a quick chat to the bloke at a set of lights.
I'm guessing he works right opposite where I see his car parked all the time, either at the smash repairers or tyre place on the other side of that T-junction.
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
