Spotted "GTR 032" on the freeway.... going a lil too fast for me to sit behind for too long... lol
Hey,
I was hoping that was someone on here :cheers: nice GTR
I was only sitting on about 115k's, i kinda waited for you for a while but I lost ya :D
Jono
also spotted a yellow 34 driving down parramatta road from chatwood around 8am this morning.. can remember the plates.. i know it only had 3 letter tho..
i think i've seen that yellow R34 plates were WZN seen it turning into UWS at para
kabab doesn't even post, let alone come to cruises! he doesn't love us anymore :(
ummm this was awhile ago...but spotted last Saturday - a (silver?) R33 on the Northern Road...gave us a big wave out the window, sorry mate, would have waved back but you went by so quick and my window was up, but if it was anyone here, we were the red series 1 and black series 2 R33's that you waved at :)
We were on our way to Windsor to stay overnight before the Putty Rd cruise..
also spotted further up the Northern Rd...about a million GTiR's!!! Must have been a cruise on??
Hey,
I was only sitting on about 115k's, i kinda waited for you for a while but I lost ya ;)
Jono
115?!?!?!? HA HA HA.... when I first sat behind you I got up to about 130 before I backed off and gave up... lol
Thanks man, Yours looked awesome, a lot cleaner than mine ;) lol
spotted
S2 R33 with custom Ford purple paintjob......and blue r32 gtr
all at the one set of lights with me....hehe rare opportunity to see 32,33 and 34 together.....
i hope the 4wd is better in the wet..cause both myself and the 33 were sideways comin out of a roundabout.....
Went down to Wollongong today, saw a black 33 GTR in Warrawong..then in Crown St Wollongong saw a crazy ass 31..white with silver GT wing, big chromies and rear lights had been replaced with individual clear trailer style lights that stuck out of the back..looked really cool. Wish I'd taken a photo.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
