Just wondering if anyone has taken a r34GTT semi auto to it's limits? I'm aiming for 300-350 rwhp and just wondering if the box will handle anything around the 300 mark??? Pretty much will my gearbox detonate over a certain hp?
https://www.sau.com.au/forums/topic/292097-r34-auto-gearbox-detonation/
Put good fluid in and it should last a long time, if your worried about blowing it up use a transmission cooler.
Yeah cheers, got the trans cooler, just wondering if they're rated to a certain horsepower?
Mine has been living with 320awhp for a fair while now.. I think it's a bit tired, it slips wickedly 1st>2nd unless I back off slightly or bounce the limiter once but that could just be the ECU not pulling timing. 2nd>3rd and 3rd>4th seem fine.
P.S. it's a 4wd Stagea but it's pretty much the same box but with a transfer case stuck on the end.
Stan (Satanic) had the flex plate let go, but that was around the 300rwkw mark. My car has had 300rwhp going through it for years now, changed the fluid over and that fixed slipping.
A full box build though with kevlar bands and a shift kit would be a good upgrade. Don't get the shift kit without upgrading the bands, you'll brake the standard bands real quick.
Edited by 666DAN
Cheers guys, will probably build the box just to make sure.
  • 1 month later...
Hi guys, its nice to see some chat about autos goin on. sometimes find it hard to get info on them as everyone has manuals. its also nice to see fella's pullin some nice power figures through them too. well done.....
quick question, anyone seen a stall converter in a skyline. do you need to prep the box in any way prior to doing so, or would they be ok straight up. what stall would be the go?
first i've heard of that. you've got me worried now
Where do you get the kevlar bands from? $$$? Are they a prick to put in?
  • 3 weeks later...
Where do you get the kevlar bands from? $$? Are they a prick to put in?
Should be able to get them from where ever you got your shift kit from.. Or try calling MV Automatics and see if they have them.
Keeping on topic..
I'm thinking about pushing more power on my R34 Auto.. I'm going to be getting my turbo high flowed either by GCG or HyperGear so that its able to push between 16 - 20psi.
Got a PWR 19 Row Transmission Cooler lined up to replace the stock one. Anyone got an idea on how many row the stock tranny cooler is, haven't pulled my front bar off to look yet.
Will possibly be buying a shift kit from MV Automatics but I'm still wondering to myself is this going to make my gearbox last?
Since the shiftkit would be putting more strain on my gearbox and making the shifts tighter is the tranny cooler the only upgrade that can be done without rebuilding the box?
There doesn't seem to be much support for the Auto 34's here in W.A and really I wouldn't trust a local shop to be fixing up my box if it blows..
Didn't see the need to open a new thread to post my question so any help is appreciated!
I dont believe that for a second.
never heard of that happening.... other than a 330rwkw r33 that needed a auto build due to the Power-FC obviously not retarding timing on gear changes.
had my MV auto shift kit in for around 2years now and the auto box is Better Than Ever before, currently getting 250rwkw - No slip No band damage, better gear changes, etc
Its not true at all, thats why. I had one before my powerglide with 370rwkw. The first thing that
goes in the them is always 2nd gear (sprag clutch)??, that and the standard nissan torque converters explode with big power. Mates have had the same problem twice with them now aswell.
cheers
darren
cheers
darren
Then why do MV sell a complete upgrade kit for the R34 box and yet only rate that at 300rwkw? Because that's all the power even the kevlars can take with a hiding. Ask abobob how his box held up with an MV kit and 245rwkw.
Then contact Satanic and ask him what happened to his flex plate while on the dyno tuning it, a quick squirt at 330rwkw and it let go.
Meaning the bands can't take 330rwkw with a shift kit fitted.....timing or not, it's the power that killed the box.
With regards to Stan and abobob, bear in mind these are both R34 M-ATx boxes that this has happened to, not R32's or R33's
Edited by 666DAN
I think there's some confusion here; there's actually a few differing things that people are talking about:
* R33 box v R34 box
* Power v Torque
The R33 box v R34 box is totally different; not so much in how they work but moreso how they are made. The reason why my flex plate broke whilst someone like Dangerman's held is because the R34 item is wafer thin compared to the R33.
Power translates to heat, which is what kills autos... power, did not kill my flex plate though. Torque did - the stress subjected to the plate when the car hit boost on the dyno and the torque figures shot right up, mauled the plate.
I'm now up to 500rwhp and the box from MV is still going A-OK... and that is with a lot of 'spirited' driving.
My transmission setup is comprised of:
* Fully Overhauled MV Automatics Box
* MV Automatics Shift Kit
* MV Automatics Custom Flex Plate
* MV Automatics High Stall Convertor
* Davies Craig 19 Row Trans Cooler
* Defi Oil Temp Gauge (Trans Temp)
* Quality Trans Fluid
So the question should be for the OP, how do you intend on driving your car? 300-350rwhp would not immediately demand the full works. Doing so would result in a safer and more enjoyable drive though.
Pretty much right, because the torque I'm making at 220rwkw is definately beyond the capabilities of the stock R34 box if driven hard (I've learned when and when not to shift) and I know for a fact putting a shift kit in and getting sharper shifts would f**k it in weeks with my driving.
Basically if you drive like a girl though, the box will last longer in the R34......question is are you a bitch? ;)
* R33 box v R34 box
* Power v Torque
Thanks for clearing that up, useful information too.
How much torque are we talking here
My flex plate broke at 487nm... the new one is going very strong with 650 odd at the moment.
For more pics & details, see here:
http://www.skylinesaustralia.com/forums/Bi...p;hl=flex+plate
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
    • These going to fit over the big brakes? I'd be reeeeeeeeaaaall hesitant to believe so.
    • The leather work properly stunned me. Again, I am thankful that the leather was in such good condition. I'm not sure what the indent is at the top of the passenger seat. Like somebody was sitting in it with a golf ball between their shoulders. The wheels are more grey than silver now and missing a lot of gloss.  Here's one with nice silver wheels.
    • It's amazing how well the works on the leather seats. Looks mint. Looking forward to see how you go with the wheels. They do suit the car! Gutter rash is easy to fix, but I'm curious about getting the colour done.
