Which stroke would you prefer?
55 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Hang on, what we're talking about is a crankshaft for an inline 6, right?
By that logic, _those_ guys that have copied the relevant Nissan dimensions (e.g. rod-rod distance) should not be doing that; and Nissan should not be selling a 4-stroke motor with overhead cams, and ...
Far better to pool all that knowledge; get what works, and use that as a basis for future refinement. Kind of what we use the forums for. Stop people repeating the same mistakes.
R&D is about being first-to-market or improving on an existing design to make sales. I bet the very first <foo> crankshafts were simple copies of Nissan's cranks with some minor changes.
Then more technology from e.g. the racing world was imported. Did HKS invent the counter-balanced crank? No. How about knife-edging? Nup. Do some of their cranks have those features? You bet.
Have they got an advantage for being first- or best-to market? Yes. Should that advantage continue in perpetuity? Hell no.
If the design _can_ be patented (good luck doing that with a crankshaft unless it has some completely new feature) then the innovator gets some extra benefits other than actually being in the market.
Let's face it; there are only so many options for crank dimensions, design, and materials choice for the RB26. Most of those options would already have been explored.
A good crank will incorporate the good and leave out the bad. I say bring on more people making quality crankshafts.
Regards,
Saliya
I think it's more the chineese copyin, claiming it's a "HKS" yet it's made out of very low quality steel and is bent from the factory... That's the issue.
Nothing wrong with copying, so long as you're not claiming it is something it isn't, or trying to make it look like them.
77.7 please!
just jap sell a brand spanking 26 crank for $1190
but If a stroker crank was available Id get one for sure.
Edited by Mr. Untouchable
77.7 please!
the stock stroke crank will come in about the same as the above price, the 77.7mm will be dearer but not much.
count me in for a stocker than in a couple months, how long away do you reckon they'll be?
Well it's sounding very tempting then!
  • 1 month later...
  • 9 years later...
Well this thread seems to just have faded away, 73.7mm full counter crank would spin up so fast and redline around 9500 - 10?
What became of this, has any one used a 73.7mm crank?
Im looking for a Full counter normal stroke crank.
https://www.junauto.co.jp/products/crankshaft/index.html
https://www.hirano-tire.co.jp/tomei/rb26/rb26-1-5.html
http://www.nitto.com.au/products/crankshafts.html?vehicle=nissan
https://nlgroupautoparts.en.alibaba.com/product/60813976018-805081960/Top_Quality_Billet_Racing_Crank_shaft_for_Nissan_RB26_RB26dett_Engine_Crankshaft.html?spm=a2700.icbuShop.41413.19.746a66b5HATbqZ
Have you seen this?
JUN Auto is about an hour from my house:)
TOMEI has had some internal conflicts resulting in a split between both founders, a subsequent business opened called Real Speed Engineering or RSE , oddly enough since both parties are were founders both parties share the patents LOL
I was looking at some of their cams a while back and was wondering where they popped up from. Ended up getting some custom Camtechs out of NSW made up instead to feed the EFR.
So has one partner started RSE and the other still running Tomei?
You should put a Jun 2.8 kit or the famous 2.7 seeing as how they are so close, they can do your block also and set it up perfect!
I'm about 5 hours drive away from you by the look of it.
    • I guess one thing that might be wrong is the manifold pressure.  It is a constant -5.9 and never moves even under 100% throttle and load.  I would expect it to atleast go to 0 correct?  It's doing this with the OEM MAP as well as the ECU vacuum sensor. When trying to tune the base map under load the crosshairs only climb vertically with RPM, but always in the -5.9 column.
    • AHHHH gotchaa, I'll do that once I am home again. I tried doing the harness with the multimeter but it seems the car needed a jump, there was no power when it was in the "ON" position. Not sure if I should use car battery jump starter or if its because the stuff that has been disconnect the car just does send power.
    • As far as I can tell I have everything properly set in the Haltech software for engine size, injector data, all sensors seem to be reporting proper numbers.  If I change any injector details it doesnt run right.    Changing the base map is having the biggest change in response, im not sure how people are saying it doesnt really matter.  I'm guessing under normal conditions the ECU is able to self adjust and keep everything smooth.   Right now my best performance is happening by lowering the base map just enough to where the ECU us doing short term cut of about 45% to reach the target Lambda of 14.7.  That way when I start putting load on it still has high enough fuel map to not be so lean.  After 2500 rpm I raised the base map to what would be really rich at no load, but still helps with the lean spots on load.  I figure I don't have much reason to be above 2500rpm with no load.  When watching other videos it seems their target is reached much faster than mine.  Mine takes forever to adjust and reach the target. My next few days will be spent making sure timing is good, it was running fine before doing the ECU and DBW swap, but want to verify.  I'll also probably swap in the new injectors I bought as well as a walbro 255 pump.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
