Hi People,
I have a fresh mystery at hand (without solving that other one about a disconnected hose in engine bay).
Yesterday when driving home, I noticed a squeaking noise (sort of like the springs of on old bed) coming from the rear left of the car every time I would turn. When walking away, I saw a dettached cable coming out from underneath the back of my car (R34 gtt). It seems to be a steel cable wrapped in what looks like a thermal/heat-proof material. The end seems to have some threading (suggesting that it may screw in somewhere, or something screws onto it). But I can't seem to see anything except a few holes in the underbody (nothing with threading) where it may attached to.
The first pic shows what it basically looks like. The second pic shows where it is attached (on the back left, inside the "support" for the rear bumper i guess). There isn't one on the other side (the place where it would go is plugged by a piece of rubber).
It's on the side of the exhaust...So I'm thining it might be a cable to support the exhaust? But I've never seen a exhaust supported by a cable.
-Is it possible the exhaust was making the squeaking noise when the car was turning?
-Is this cable to support something to do with the suspension etc? if so, why would it be attached to the the inside of the bumper support?
-Is it some sort of grounding wire?
http://i962.photobucket.com/albums/ae103/v.../IMAG0130-1.jpg
http://i962.photobucket.com/albums/ae103/v...23/IMAG0131.jpg
The next time someone looks under their R34, please let me know what this is and what it connects to? Or if you want to be an absolute legend, take a pic on your phone :)
Edited by DriftinThruLife
Its for the genuine exhaust. Low throttle one of the exhausts close/restrict, but once you start getting the revs up it opens up. It mentions it on the R33 factory manual - the r34 factory manual does not mention it..... *someone please correct me if I'm wrong.*
hi, yep i thought that too when i looked at it. although on the 33 its closer to the front of the car, but I do think that imho that is what it is. obviously the exhaust is not stock. and they didnt incorporate this.
My GTT has a big stainless steel bracket for the aftermarket muffler in the same spot. nothing else
it wouldnt be a handbrake thats not even close to it.
to test , with cool tailpipe, lay on the ground and wiggle the muffler, 90% sure its a broken off bracket on it. and it would squeak like a old truck on corners/take off. bumps etc.
unless its something added by the aliens ????
Hey all, thank you sooo much for your replies. This morning I was like "damn zero replies"...and now it's like "ch-ching! jackpot".
The fact that a few of you don't have it, puts my mind at ease...since it's not an absolutely necessary thing. Just out of curiosity..those of you who don't have it...do you have stock or aftermarket exhausts?
Since iseekool mentioned it's for the geuine/stock exhausts...mine's aftermarket, yet the cable is there. But I'm guessing it WAS getting used, since the dettached cable and squeaking happened at the same time. unless it's a coincidence?
I'll start looking more closely around the exhaust area, and see if I have any luck. If I can't attach it normally, I guess I could make some sort of metal harness for the exhaust to sit in (as long as that squeaking stops).
PS: i seekool...is that anything to do with the SPORT/SILENT exhaust switch? Whenever i press it, I can hear something moving...but don't notice anything sound-wise...I guess coz it was meant for the standard exhaust.
Once again, Thank you all veryy veryy veryy much :(
Once again, Thank you all veryy veryy veryy much :P
I just recently changed my exhaust and there was no such contraption on the stocker.
Once again, Thank you all veryy veryy veryy much :down:
Kaching! Lol!
My bet would be that if you looked under the car at that thing while a mate pressed the exhaust switch it might move :blink:
It kinda looks similar to an actuator of sorts. And if it was for the factory muffler then it would open/close something inside.
Hi People,
The next time someone looks under their R34, please let me know what this is and what it connects to? Or if you want to be an absolute legend, take a pic on your phone :blink:
My guess is, it is your Exhaust Temperature Sensor.
If you had a look, there should be a EXH Temp Warning embroidered on your sun visor on the driver side, in Japanese (That's probably why you didn't read it LOL!)
Again that's for the R32, on the R34 maybe different...
I know R32's had them and mine has been cut off, just a cable hanging cuz of my aftermarket exhaust when it came with the car.
But R32's had it near the Cat converter... That's why I can only guess for the R34.
Exhaust Temp Sensor is there to warn you, when the exhaust gets really hot, the temp light will come on.
How does an exhaust get hot? When the engine is running, giving it a good spirited run down the track, but were talking excessively high temps.
That's my guess.
That's my guess.
I actually think your referring to a cat temp sensor, rather than an "exhaust temp" sensor.
Every car i have had has it, and its actually there more to tell you that your cat is f**ked/blocked.
Because the cat catches all the nasties, over time it clogs up and causes restrictions. And the restriction will obviously create alot more heat than normal because your forcing the same amount of exhaust through a more restricted area.
If the cat is in good working order, or not there at all (decat), you shouldnt ever see the temp light on the dash come on at all, even on the track.
Oh i see. Thanks guys. Eiher way...whether it's some sort of cable for pulling (silent/sports mode) for the standard exhaust....or a cat temp sensor as you have mentioned....I guess I should leave it on (as opposed to cutting it off) just incase I ever have to put the standard exhaust back on. But yeh, for now I've just just used a cable tie to hold it up and away from the road. Still don't kow what that squeaking is. maybe something wrong with the suspension. I don't know. Oh well. But I guess the cable mystery is over.... Now i'll have to try and solve that other thread I have....about the mysterious unconnected hose in the engine bay. Thanks for everything people. Very very appreciated =)
I see,
That makes sense, thanks for clearing that up :)
What I said in my post is what I was told, but your answer makes more sense.
Cool!
:laugh:
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
