ohh nice one stirlo a yellow gtr, show be able to spot you a mile away then hee hee. should look awesome when finished.
yeah the qbn workshop choka packed with the usual...umm....suspects. hee hee good to see ed looking after 'em. not many workshops around that offer the service ed does.
https://www.sau.com.au/forums/topic/30059-spotted/page/89/#findComment-1100731
spotted a white R33 with chromies, and a red R33, plates were D***
and myself(blushes) doing a drop off at the ginnenderra formal at rydges this evening.
edit: also a nice silver R33 on i think its william hovell this evening at about 6. gave a wave and got a big one back
https://www.sau.com.au/forums/topic/30059-spotted/page/89/#findComment-1100780
Yeah - that blue one tubbed up not so bad, dont know about the running gear, She be for sale too.
Saw Amaru (I think), Sinister plus a nice blue 32 and a couple of others at the usual Qbyn workshop today.....
I'm starting to wonder
" Am I ever gonna drive my ride again" No way, Get !@#$, %^&* off !" :) :goddam:
https://www.sau.com.au/forums/topic/30059-spotted/page/89/#findComment-1100906
Saw Amaru, Sinister at integra, also at about 6:30 on my way to work a silver 33 very tidy driving along uriara road in queanbyean :):)..
also a couple of days ago (22nd of november)at like 5:50 turning towards the rubbish tip a midnight purple r32 with white rims, verry nice :):D:D
https://www.sau.com.au/forums/topic/30059-spotted/page/89/#findComment-1100954
Sounds like my grad dinner.
They decided to put it on the night of the Union World Cup final. Bad idea.
I was yelling at the union at the top of my lungs after ridiculous amounts of alcohol. Although was quite funny to see lots of the straighter lecturers having a bit to drink.
https://www.sau.com.au/forums/topic/30059-spotted/page/89/#findComment-1102938
Spotted:six of us in a row on Friday night!So you could say we were in a line,in our 'Lines to stop on the line-at the Lakeside Rydges for a formal.By memory,there was Choochoobar,SxyGTST,WhyTry,Sinista32,SupaFly Skyline plus little old me(no comments 'bout the age thing,you lot!) plus an R33 in grey that was happy to zip around us as we drove in(anyone on the forums?).Those that haven't been treated to SxyGTST's ride lately need to see it now:the rims now match the rest of the car-schweeeet!
Plus seeing Alf's cameleon R33(AJC plates),pretty sure I saw JohnnyR31,a coupla white R33 GTST's,a silver R33 GTR...Pretty good night for spotting 'Lines,really!
https://www.sau.com.au/forums/topic/30059-spotted/page/89/#findComment-1103057
  needless to say the coper wasn't too happy bout it after he pulled me over, was bout to give me ticked, when a snaper head in a commodore came speeding round the corner and went after him. long live the idiots in commowhores.
Hahahahaha!Snapper heads in Commonwhores! :bahaha: where would we be without 'em?Well,in WhyTry's case,booked or locked up!!
https://www.sau.com.au/forums/topic/30059-spotted/page/89/#findComment-1103060
    • So, this shouldn't be such a mission, but there were a few tricks so I thought I'd post up a DIY for it. This was on a Q50 Red Sport but I doubt any other V37 model is very different (maybe just less steps for the intake heat exchanger hoses) I pulled the radiator out to flush it because the car was running hot at the track, but obviously the same steps apply for changing a radiator for any reason including an upgrade. If you are removing the radiator, you of course need to drain and refill, so have 5+ litres of blue coolant ready. You don't need to drain the intake heat exchanger to remove the radiator but depending on your plans you may need a couple of litres for that as well. You will also need something to deal with the auto transmission lines, I used 2x 8mm rubber caps on the radiator side, and a short length of 8mm pipe on the car side.....unless you can block these lines quickly you will loose AT fluid and it may be enough to hurt the transmission if you don't refill it. Other than that....lets go... "First, jack up your car". Yes really, and put it safely on stands. If you are not confident doing that you need to give this job to a mechanic
    • If the forester is anything like our old 2007 GTB Liberty, I could near on run ling Long's and "rate them", as no matter what, it just hung to the road, even when abusing it in a hard launch in the wet, or throwing it at corners.
    • LOL, all of the CAI like Craig I just need to put a hole saw through my bumper Done and dusted, the car runs, which is nice, I'll take it for a spin when the weather clears up Just need to put the bumper back on for good
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
