Hi all im a newbie here, met all of you at the Hawker formal tonight! I was in the Silver R33 Gtst SII that Sxygtst (jon) used to own. It was possily my biggest "Spotted" when I cleared the crowed and drove round to find about 10 (maybe more) hot lines' parked lining the exit! (all of you guys) So thanks to SINISTA (richard?) for introducing me and I look forwardto cruising with you guys!
Anyone spotted me recently? Silver R33 GTST SII? Stock apperance but loud and frequently sideways? I cant get a pick small enough to use as my Avatar!
https://www.sau.com.au/forums/topic/30059-spotted/page/95/#findComment-1115786
p1r4t8r, its not me! I make an effort to wave and nod to everyone driving a skyline! I dont have P-plates on the car but the boys in blue would probably like me 2 for another couple of months!
choochoobaa, sorry also not me! (that I can remember) It was an awesome turnout I agree!
https://www.sau.com.au/forums/topic/30059-spotted/page/95/#findComment-1115861
Hi Stevie, Welcome mate:wavey:. Yep a nice turnout indeed. Tis the first time I've seen your line. Look forward to catching up and cruising more often. Mayhaps see you at Jerra on Tuesday. :)
Richard.
PS. I still cant get an Avatar of my precious to the right whatever's :)
https://www.sau.com.au/forums/topic/30059-spotted/page/95/#findComment-1116003
Spotted! me driving like a grandma because my cluctch slipped to the point where it revs whenever you put your foot down! hooray! booked it in with Ed, looking at $1000 for a new Exedy clutch installed, apparently slightly better than stock. I'm not a lead foot so it should do, but ouch! $1000 so close to christmas! i could cry!
https://www.sau.com.au/forums/topic/30059-spotted/page/95/#findComment-1116131
i followed a silver 33 to the formal tonight cause i had no idea where i was goin. maybe that was u stevie? sorry for cutting u off a few times but the traffic was a bitch and if i lost ya then i woulda been screwed.
good turn out tonight anyways
I think that was me, you had two passengers right?
https://www.sau.com.au/forums/topic/30059-spotted/page/95/#findComment-1116136
Yeah, i was reading it last night. I knew my clutch was on the way out so i was looking at my options. I'm just going with what Ed offered. I need the car back as soon as possible and this will be the quickest way. Maybe not the cheapest, but hey, I trust Ed to do a good job, and if that means i pay an extra $100 or two on top i dont mind.
But thanks anyways. Oh and that reminds me, i owe you a drink sometime for a certain thing you did to a certain Falcon. :)
https://www.sau.com.au/forums/topic/30059-spotted/page/95/#findComment-1116158
Integra Automotive in lanyon drive in queanbeyan (at the mobil servo just past the fixed speed camera after jerra).
Or you can call on 62329329
Im sure he would be relieved to just do a normal service instead of working on mine and sinistas car, hes probably sick to death of both of them by now :)
https://www.sau.com.au/forums/topic/30059-spotted/page/95/#findComment-1116225
    • Lets say I wanted to buy this, specifically for this purpose. How do I actually perform the function. Can I still buy a Consult-1? Am I about to be burned by the fact my car is a 2000 model Series 2 R34 and thus will be some stupid other system? Do I just need this -> https://obd2australia.com.au/product/nissan-consult-14-pin-to-usb-ddl-diagnostic-interface-with-ftdi-ft232r-chip/ And with what software?
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
