Spotted a blue R33 series 1 as i was leaving my street, waved but he didn't wave back. Then a black R33 Series1.5 on the way to work near Bunnings, waved and got one back. Also spotted a Silver R33 GTR heading to Tuggers from Chisholm, waved and think i got one back. And finally a black Series II with GTR wing near BP Chisholm, waved but got nothing back.
https://www.sau.com.au/forums/topic/30059-spotted/page/114/#findComment-1161813
Ok havent been on for a few days, so sorry guys this is delayed spotted sexy gtst at bout 6 driving towards jerra on the 13th.
Also on da 13th:
*A black 33gts-t black plate ewing rims? at UPS in fyshwick
*A gold/yellow (bit of both very nice like white gold) 33 at 11 driving past bunnings, went past too quick but gotta say it got my attention!
*Another gold 33 on barrier st about 11 15, very tidy chrome rims
*Gun metal 32 near maccas traffic lights (fysh) 1:50pm :)
*White 32 gts-t white 5 spoke rims, vic plates
One of the best days for spotting, and no comments about why i was in fychwick i work as a courier!
https://www.sau.com.au/forums/topic/30059-spotted/page/114/#findComment-1163754
Yellow R34 at curtin shops with the number plate NISSAN yesterday
soon to be my new boss :headspin: , just officially been offered the job i've been hunting for with him!
spotted a few lines over the last couple of days, (i've done 300kms in 2 days and the car is boring me lol) gaves waves to them all, got none back, SCROOGES!!!!
https://www.sau.com.au/forums/topic/30059-spotted/page/114/#findComment-1164162
haha, 300km in 2 days, i went from Canberra, Bathurst, Sydney, Bathurst back to Canberra in 2 days. about 1100km trip i think. half of it was on new wheels though.
Spotted a Silver R33 in the city, gave a wave but no reply.
https://www.sau.com.au/forums/topic/30059-spotted/page/114/#findComment-1164349
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
